New Edge Mustang - Turbo LQ4/T56
#221
WHAT AN EMOTIONAL ROLLER COASTER....
UPDATE TIME:
So got the car close enough on the tune to be able to drive it down the road, ended up having the hood fly up on me and smashing the windshield and dash.
![New Edge Mustang - Turbo LQ4/T56-p4zotdnl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715078d1683231977t-new-edge-mustang-turbo-lq4-t56-p4zotdnl.jpg)
![New Edge Mustang - Turbo LQ4/T56-cxzgoall.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715079d1683231977t-new-edge-mustang-turbo-lq4-t56-cxzgoall.jpg)
![New Edge Mustang - Turbo LQ4/T56-7cliefjl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715080d1683231977t-new-edge-mustang-turbo-lq4-t56-7cliefjl.jpg)
Had enough force to rip one of the mounting bolts out of the body.
![New Edge Mustang - Turbo LQ4/T56-n9xudqwl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715081d1683231977t-new-edge-mustang-turbo-lq4-t56-n9xudqwl.jpg)
![New Edge Mustang - Turbo LQ4/T56-dihl7dyl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715082d1683231977t-new-edge-mustang-turbo-lq4-t56-dihl7dyl.jpg)
Installed hood LATCHES the following day lol.
![New Edge Mustang - Turbo LQ4/T56-prummhxl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715083d1683231977t-new-edge-mustang-turbo-lq4-t56-prummhxl.jpg)
After that happened i also noticed a small little coolant leak, turns out that LS1 f body pump does not allow for a swivel thermostat. After some researching i found that i can use a ls2 which has the smaller thermostat opening, allowing me to use the swivel. I also rigged up this nice little tool to pull the fittings out to tap and thread some 90 degree fittings.
![New Edge Mustang - Turbo LQ4/T56-uhuas0al.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715084d1683231977t-new-edge-mustang-turbo-lq4-t56-uhuas0al.jpg)
![New Edge Mustang - Turbo LQ4/T56-clidflal.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715085d1683231977t-new-edge-mustang-turbo-lq4-t56-clidflal.jpg)
Spoiled myself with a nice digital dash w/ GPS module.
![New Edge Mustang - Turbo LQ4/T56-hfbysiil.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715086d1683231977t-new-edge-mustang-turbo-lq4-t56-hfbysiil.jpg)
![New Edge Mustang - Turbo LQ4/T56-fydycpyl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715087d1683231977t-new-edge-mustang-turbo-lq4-t56-fydycpyl.jpg)
Finally got around to dropping the car off at the dyno last Thursday, made some good steam. Made 454/444 on a mustang dyno on 5lbs.
Pushed a little harder.
Ended up hearing that all to familiar sound after this pull. Pulled the valve covers, all rockers were tight... no sign of lifter problem. Changed oil, no glitter. Okay something must be up, lets pull the head and see if its the lifters still. MIND YOU this is still friday night.
![New Edge Mustang - Turbo LQ4/T56-jvveq2ql.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715088d1683231977t-new-edge-mustang-turbo-lq4-t56-jvveq2ql.jpg)
![New Edge Mustang - Turbo LQ4/T56-ocnfauul.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715089d1683231977t-new-edge-mustang-turbo-lq4-t56-ocnfauul.jpg)
![New Edge Mustang - Turbo LQ4/T56-1of6j9ul.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715090d1683231977t-new-edge-mustang-turbo-lq4-t56-1of6j9ul.jpg)
![New Edge Mustang - Turbo LQ4/T56-vjqxnuzl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715091d1683231977t-new-edge-mustang-turbo-lq4-t56-vjqxnuzl.jpg)
So at this point im cursing and thinking about torching the car outside in the driveway lol. The whole time i have been working on this car to get it ready for Hot Rod Power Tour, now i have to cancel my trip. I thought for about an hour on what to do, then i got a wild hair up my *** and decided to swap everything over to my old 6.0 and try and get it back on the dyno and tuned before the weekend was over!
Unwrapped my 6.0
![New Edge Mustang - Turbo LQ4/T56-qianbak.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715092d1683231977t-new-edge-mustang-turbo-lq4-t56-qianbak.jpg)
Remove old 5.3
![New Edge Mustang - Turbo LQ4/T56-52mwivhl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715093d1683231977t-new-edge-mustang-turbo-lq4-t56-52mwivhl.jpg)
Changing over the springs to the 317 heads.
![New Edge Mustang - Turbo LQ4/T56-cotm2tzl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715094d1683231977t-new-edge-mustang-turbo-lq4-t56-cotm2tzl.jpg)
![New Edge Mustang - Turbo LQ4/T56-882ho3ql.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715095d1683231977t-new-edge-mustang-turbo-lq4-t56-882ho3ql.jpg)
Short-block coming together
![New Edge Mustang - Turbo LQ4/T56-4zlbjixl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715096d1683231977t-new-edge-mustang-turbo-lq4-t56-4zlbjixl.jpg)
![New Edge Mustang - Turbo LQ4/T56-m0btfg6l.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715097d1683231977t-new-edge-mustang-turbo-lq4-t56-m0btfg6l.jpg)
Installed in the engine bay!
![New Edge Mustang - Turbo LQ4/T56-kw3jg1xl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/715098d1683231977t-new-edge-mustang-turbo-lq4-t56-kw3jg1xl.jpg)
At 10:00PM on Saturday night I finally did it. So in 30 hours I diagnosed what was wrong, removed the 5.3, changed springs, installed all my goodies into the 6.0, and reinstalled a new motor into the car!
My tuner did not work Sunday, but this was yesterday. Car made 527/542 on 9 PSI. Still there today making some adjustments and cranking up the boost some more.
Still planning to do the Hot Rod Power Tour as well! Ill update you guys on tonight's numbers!
UPDATE TIME:
Unwrapped my 6.0
Remove old 5.3
#223
UPDATE TIME:
![](https://i.imgur.com/p4zOTDNl.jpg)
![](https://i.imgur.com/cXzgoALl.jpg)
![](https://i.imgur.com/7CLIEFjl.jpg)
![](https://i.imgur.com/N9XUDQwl.jpg)
![](https://i.imgur.com/DIHl7DYl.jpg)
![](https://i.imgur.com/pRUMMHxl.jpg)
![](https://i.imgur.com/UhuAs0Al.jpg)
![](https://i.imgur.com/CliDFlal.jpg)
![](https://i.imgur.com/HfbysiIl.jpg)
![](https://i.imgur.com/FYDYcPyl.jpg)
5/31/19 Dyno Day
![](https://i.imgur.com/JVVeq2ql.jpg)
![](https://i.imgur.com/OcnFauUl.jpg)
![](https://i.imgur.com/1OF6J9ul.jpg)
![](https://i.imgur.com/vjQxnuzl.jpg)
Unwrapped my 6.0
![](https://i.imgur.com/qIanbAk.jpg)
Remove old 5.3
![](https://i.imgur.com/52mwivHl.jpg)
![](https://i.imgur.com/COtM2TZl.jpg)
![](https://i.imgur.com/882HO3ql.jpg)
![](https://i.imgur.com/4zLbJiXl.jpg)
![](https://i.imgur.com/m0bTFG6l.jpg)
![](https://i.imgur.com/kW3jG1xl.jpg)
6.0 First Start
6/3/19 Dyno
UPDATE TIME:
5/31/19 Dyno Day
Unwrapped my 6.0
Remove old 5.3
6.0 First Start
6/3/19 Dyno
#225
Dude you are a total animal. I can't believe you got that all done in a day. What bounced around in that cylinder? Spark plug end bust off? At least you had the trusty old 6.0 laying around haha. You'll get some pretty numbers from that motor all said and done. Any plans for the next motor or are you just going to run that one til it blows? Either way congrats.
I guess I better update a little bit from the last month or so.
Car ended up making a measly 567hp/530tq on 12lbs and 10 degrees of timing on a mustang dyno, so it should be somewhere close to 630rwhp if corrected. We kept popping the intake boot off, so i need to have a v band welded onto the throttle body and switch to a solid piece right there at the 90 degree boot. So we left her where she was, set the Holley Dominator to revert to waste gate at 11.9 PSI in order to keep me from blowing the boot while on Hot Rod Power Tour.
Had a small bit of oil pushing from the bottom end somewhere while on the dyno, which we thought was because of not running a catch can. Turned out that it was the o-ring missing and the bottom of the f-body dipstick tube broken off in the pan.... not really sure how it happened but not it has a Lokar installed.
![New Edge Mustang - Turbo LQ4/T56-zeyv7jal.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714894d1683231826t-new-edge-mustang-turbo-lq4-t56-zeyv7jal.jpg)
Night before i was scheduled to leave to drive 6 hours to Charlotte for Hot Rod Power Tour i went to start the car up after a fresh oil change and noticed oil all over the ground... rubbed a hole somehow through the oil feed line to the turbo. So i overnighted parts from summit to Charlotte and replaced the oil feed line when i got there Friday night. Sucks that I had to trailer it the whole way, but ended up working out as i had to drop a truck off at a family members anyways.
![New Edge Mustang - Turbo LQ4/T56-vffdexgl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714895d1683231826t-new-edge-mustang-turbo-lq4-t56-vffdexgl.jpg)
![New Edge Mustang - Turbo LQ4/T56-wbejcfxl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714896d1683231826t-new-edge-mustang-turbo-lq4-t56-wbejcfxl.jpg)
![New Edge Mustang - Turbo LQ4/T56-u3v4lkhl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714897d1683231826t-new-edge-mustang-turbo-lq4-t56-u3v4lkhl.jpg)
Other than that the car ran absolutely wonderful on the Power Tour. I was averaging about 15-17 mpg most of the time with some aggressive driving, and 25 mpg on the highway in 6th gear on the way back from Norwalk. Only hiccup i had was that i rubbed through the Power Steering line in Bristol, so i bypassed the pump and limped it to my house on the next leg of the trip.
![New Edge Mustang - Turbo LQ4/T56-fd8w9nxl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714898d1683231826t-new-edge-mustang-turbo-lq4-t56-fd8w9nxl.jpg)
![New Edge Mustang - Turbo LQ4/T56-dv30ktwl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714899d1683231826t-new-edge-mustang-turbo-lq4-t56-dv30ktwl.jpg)
![New Edge Mustang - Turbo LQ4/T56-zox5tozl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714900d1683231826t-new-edge-mustang-turbo-lq4-t56-zox5tozl.jpg)
![New Edge Mustang - Turbo LQ4/T56-f4yfdgtl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714901d1683231826t-new-edge-mustang-turbo-lq4-t56-f4yfdgtl.jpg)
![New Edge Mustang - Turbo LQ4/T56-c0b1n7vl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714902d1683231826t-new-edge-mustang-turbo-lq4-t56-c0b1n7vl.jpg)
![New Edge Mustang - Turbo LQ4/T56-qfbxdiql.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714903d1683231826t-new-edge-mustang-turbo-lq4-t56-qfbxdiql.jpg)
Some people sent me these that they took while on the tour, never thought my car would get anyones attention. But when you have the hater pipe and hood opened it raises questions lol!
![New Edge Mustang - Turbo LQ4/T56-b0jchqvl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714904d1683231826t-new-edge-mustang-turbo-lq4-t56-b0jchqvl.jpg)
![New Edge Mustang - Turbo LQ4/T56-oftdncjl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714905d1683231826t-new-edge-mustang-turbo-lq4-t56-oftdncjl.jpg)
![New Edge Mustang - Turbo LQ4/T56-immpbt4l.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714906d1683231826t-new-edge-mustang-turbo-lq4-t56-immpbt4l.jpg)
![New Edge Mustang - Turbo LQ4/T56-n0pgsqxl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714907d1683231826t-new-edge-mustang-turbo-lq4-t56-n0pgsqxl.jpg)
![New Edge Mustang - Turbo LQ4/T56-jhtfavfl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714908d1683231826t-new-edge-mustang-turbo-lq4-t56-jhtfavfl.jpg)
Anyways, just thought i would let you guys know the car is still kickin!
#226
Well boys and girls the car is sold to a new owner down in Southern TN. It was fun! Got a offer on the car i couldnt refuse. Ill be back into something else later on down the road. Thanks for everyones help, and thanks to all the friends i made on here during this journey.
This is how the car looked right before i sold it, and right on trailer.
![New Edge Mustang - Turbo LQ4/T56-h4vjtgol.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714700d1683231577t-new-edge-mustang-turbo-lq4-t56-h4vjtgol.jpg)
![New Edge Mustang - Turbo LQ4/T56-wsswagrl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714701d1683231577t-new-edge-mustang-turbo-lq4-t56-wsswagrl.jpg)
![New Edge Mustang - Turbo LQ4/T56-57duvmtl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/714702d1683231577t-new-edge-mustang-turbo-lq4-t56-57duvmtl.jpg)
#227
IM BACKKKKKK, Ended up buying the car back from the guy I sold it too.
Its got no drivetrain, the ecu is gone, the rear end is sold, and most the cobra parts are gone... BUT it has the fuel system, a roll cage and full interior in it now.
![New Edge Mustang - Turbo LQ4/T56-jlixqtqh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/713421d1683230724t-new-edge-mustang-turbo-lq4-t56-jlixqtqh.jpg)
![New Edge Mustang - Turbo LQ4/T56-6cxw79ah.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/713422d1683230724t-new-edge-mustang-turbo-lq4-t56-6cxw79ah.jpg)
Gonna try and get this bad boy back on the road again. I actually sold this thing, bought a damn engagement ring with the money and had a fiance for about 2 months lol. Needless to say im glad i got it back.
#229
im thinking gen4 5.3 for now, forced inductions billet s480, powerglide, Holley Terminator X.
Car is already setup fuel wise to handle 1200+ crank HP, I’ll need to send another new edge length rear end out to Tin Soldiers Racing in northern Kentucky for a battle ready 8.8 kit to be installed. Had good luck with them and you can’t beat their service.
I already have FID 2200 injectors, Terminator X Max, gen 4 5.3 that was slated for the Monte Carlo, but this is taking precedence now.
I’ll need to find a powerglide, PPP Shifter, turbo, intercooler, driveshaft, radiator, and a couple other things to get it ready.
#230
![](https://i.imgur.com/jLixqTQh.jpg)
![](https://i.imgur.com/6CXW79Ah.jpg)
#231
Me too, got it just the way i have always wanted and then sold it a week later lol. Bad part is I still have the damn ring because they wouldnt take it back!
It should be fun, im supposed to be picking it up sometime in the next two weeks. Its gonna be a slow start at first as i still need to get my Monte Carlo in paint. But after the Monte is in paint its game on!
#234
So the car is pretty much as follows:
Exterior: Stock rear and front bumpers, wingless decklid, Kaeneen 5" bolt on hood, cobra side skirts, stock mirrors, 15x10 billet specialties street lites in the rear, VMS wheels in the front.
Interior: Fuse panel still there, all interior still there, has a 6 point cage in in now (ill modify this to a 10 point), has some new gauges unsure of what they are (all the Holley digital dashes are gone.)
Drive train: AJE K member still on it, power glide cross member, fox body width 8.8 (hes going to throw in 31 spline axles, spool, and c clip eliminators for free), and my entire fuel system is still in place from the Fore Fuel hat all the way up to the regulator.
So needless to say I got my work cut out for me, but it should be pretty easy to get it back to where it once was.
Future Plans:
Exterior: Replace all the stock parts back with Cobra parts. Change the bolt on hood to a hinged hood, don't know if ill go back to a 4" again or not. That thing was a pain in the *** to see corners with. Weld 17x4 alumistars up front, ill rock the billet specialties in the rear.
Interior: Kirkeys up front, convert the 6 point to a 10 point cage, Holley Pro 12.3 dash (already have this) don't know if it'll fit but im going to try like hell, rear seat delete, strip all the sound deadening out of it.
Drivetrain: Gen 4 5.3 for right now, ill build my backup block eventually, FI Billet s480, 1.80 Power glide, another Tin Soldiers Racing battle ready 8.8.
The ECU will be a Holley terminator for now, if i see the need for a dominator ill upgrade. This Terminator X Maxx was supposed to go into the Monte Carlo, ill reuse it in it if i upgrade. Im sure there is other stuff im forgetting.
#235
Whats up guys, little bit of an update. Life is happening all so fast, my baby girl is now 14 weeks old and although i hate not being in the garage i cant replace time with my sweet girl.
Thought id show a couple pictures of what the car looked like when i got it.
![New Edge Mustang - Turbo LQ4/T56-gtrgqtvl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712943d1683230453t-new-edge-mustang-turbo-lq4-t56-gtrgqtvl.jpg)
Inside photos, i wish i could show you all the terrible welds and how unsafe this cage was (it got removed)
![New Edge Mustang - Turbo LQ4/T56-wlqpyafl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712944d1683230453t-new-edge-mustang-turbo-lq4-t56-wlqpyafl.jpg)
Also been gathering a small arsenal of parts lol.
.660 BTR Titanium retainer valve springs with shims
![New Edge Mustang - Turbo LQ4/T56-paaro8xl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712945d1683230453t-new-edge-mustang-turbo-lq4-t56-paaro8xl.jpg)
BTR Shaft rocker kit
![New Edge Mustang - Turbo LQ4/T56-ipbnzfel.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712946d1683230453t-new-edge-mustang-turbo-lq4-t56-ipbnzfel.jpg)
![New Edge Mustang - Turbo LQ4/T56-sums3uol.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712947d1683230453t-new-edge-mustang-turbo-lq4-t56-sums3uol.jpg)
Moroso breathers (Used)
![New Edge Mustang - Turbo LQ4/T56-vukhoghl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712948d1683230453t-new-edge-mustang-turbo-lq4-t56-vukhoghl.jpg)
FI Billet S488/96
![New Edge Mustang - Turbo LQ4/T56-1zdbh2sl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712949d1683230453t-new-edge-mustang-turbo-lq4-t56-1zdbh2sl.jpg)
![New Edge Mustang - Turbo LQ4/T56-am50an0l.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712950d1683230453t-new-edge-mustang-turbo-lq4-t56-am50an0l.jpg)
Sitting next to my Gen3 VSR 7875
![New Edge Mustang - Turbo LQ4/T56-7fz96iyl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712951d1683230453t-new-edge-mustang-turbo-lq4-t56-7fz96iyl.jpg)
4" intercooler from Rob Dahms
![New Edge Mustang - Turbo LQ4/T56-vsmyrkwl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712952d1683230453t-new-edge-mustang-turbo-lq4-t56-vsmyrkwl.jpg)
12.3 Pro Dash
![New Edge Mustang - Turbo LQ4/T56-baqzip5l.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712953d1683230453t-new-edge-mustang-turbo-lq4-t56-baqzip5l.jpg)
Also got a Team Z 10 Point chromoly cage, thru-floor subrame connectors, Holley Dominator ECU, Holley Hooker Turbo Manifolds, Codion chromoly Tubular Front End, Strange 10 Ways, 04 8.8 to send out to be built, Fore Triple 525 pumps, and a couple other small parts.
Decided to cut out the crap cage from the car as well as cut out all the wiring from my version of the car and what the last owner did to it so i could start over fresh.
![New Edge Mustang - Turbo LQ4/T56-ipygolil.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712954d1683230453t-new-edge-mustang-turbo-lq4-t56-ipygolil.jpg)
![New Edge Mustang - Turbo LQ4/T56-7evebjgl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712955d1683230453t-new-edge-mustang-turbo-lq4-t56-7evebjgl.jpg)
Decided while i was that far, and i just parted a 04 GT out that i was going to go back to AC because street/race car lol. so i had to remove all my delete panels and weld up the holes.
![New Edge Mustang - Turbo LQ4/T56-y9onkqgl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712956d1683230453t-new-edge-mustang-turbo-lq4-t56-y9onkqgl.jpg)
![New Edge Mustang - Turbo LQ4/T56-mn5zsivl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712957d1683230453t-new-edge-mustang-turbo-lq4-t56-mn5zsivl.jpg)
![New Edge Mustang - Turbo LQ4/T56-yxy7gr3l.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712958d1683230453t-new-edge-mustang-turbo-lq4-t56-yxy7gr3l.jpg)
Switched over to a hydro boost instead of vacuum as i had issues with the vacuum booster and had this one laying on the shelf.
![New Edge Mustang - Turbo LQ4/T56-rcnojwrl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712959d1683230453t-new-edge-mustang-turbo-lq4-t56-rcnojwrl.jpg)
Then got bored and decided to cut the front end off because, why not?
![New Edge Mustang - Turbo LQ4/T56-xfjipfdl.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712960d1683230453t-new-edge-mustang-turbo-lq4-t56-xfjipfdl.jpg)
![New Edge Mustang - Turbo LQ4/T56-d12xunol.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712961d1683230453t-new-edge-mustang-turbo-lq4-t56-d12xunol.jpg)
That leaves me where i am right now. Soon as my tubular front comes in ill be mocking it up then the car will be going to my fabrication buddy to weld the connectors, cage and front end all up. I dont trust myself with moly and i needed the weight savings since im throwing AC back in it lol.
FI Billet S488/96
12.3 Pro Dash
The following users liked this post:
G Atsma (05-20-2021)
#236
Got a couple of goodies in the mail this week.
Motion Raceworks 102mm ICON throttle body with super seal connection.
![New Edge Mustang - Turbo LQ4/T56-6wgfjmdh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712792d1683230377t-new-edge-mustang-turbo-lq4-t56-6wgfjmdh.jpg)
ShearerFab 1800HP intercooler with Holley Low Ram
![New Edge Mustang - Turbo LQ4/T56-ijzgxvqh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712848d1683230377t-new-edge-mustang-turbo-lq4-t56-ijzgxvqh.jpg)
Ended up selling this one to my buddy since i got a even better deal on a 2000HP with integrated fabricated lid. Here it is mocked up on his car.
![New Edge Mustang - Turbo LQ4/T56-8sask6sh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712849d1683230377t-new-edge-mustang-turbo-lq4-t56-8sask6sh.jpg)
![New Edge Mustang - Turbo LQ4/T56-dobvqksh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712850d1683230377t-new-edge-mustang-turbo-lq4-t56-dobvqksh.jpg)
![New Edge Mustang - Turbo LQ4/T56-ngm3vq7h.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712851d1683230377t-new-edge-mustang-turbo-lq4-t56-ngm3vq7h.jpg)
The replacement for my car.
![New Edge Mustang - Turbo LQ4/T56-eaarlbhh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712793d1683230377t-new-edge-mustang-turbo-lq4-t56-eaarlbhh.jpg)
Finally got the car into the garage to mock up the front end that came in.
![New Edge Mustang - Turbo LQ4/T56-9y0hbm6h.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712852d1683230377t-new-edge-mustang-turbo-lq4-t56-9y0hbm6h.jpg)
![New Edge Mustang - Turbo LQ4/T56-xwwk1kvh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712853d1683230377t-new-edge-mustang-turbo-lq4-t56-xwwk1kvh.jpg)
Aligning some panels for final tab mounting.
![New Edge Mustang - Turbo LQ4/T56-nxhqkyxh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712854d1683230377t-new-edge-mustang-turbo-lq4-t56-nxhqkyxh.jpg)
Door gap is perfect, however the headlight alignment is not, so i am going to see if i need to brace the header panel up to twist the panels a bit.
![New Edge Mustang - Turbo LQ4/T56-i7bryw9h.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712855d1683230377t-new-edge-mustang-turbo-lq4-t56-i7bryw9h.jpg)
![New Edge Mustang - Turbo LQ4/T56-itrbbqeh.jpg](https://ls1tech.com/forums/attachments/conversions-swaps/712856d1683230377t-new-edge-mustang-turbo-lq4-t56-itrbbqeh.jpg)
I will finish welding the front end up this week and start to locate the turbo and get the kit built possibly this weekend. Sent off some measurements to Ron Davis for a custom radiator setup to fit the car and be suiteable for HotRod drag week and Rock Mountain Raceweek. The rear end should be getting sent up to my fabricator in a couple of week as well. Time to see this project start making inches to the finish line.
#239
Yup.... they're up!
Burning (06-29-2021)
