2001 Suburban 2500 engine swap
the L96 motor comes complete from GM for $5400 and is ready to install. that motor makes 360 HP with 380 Foot pounds of tork. I know I would have to do modifications on the computer for it to run properly, but it would be better for my towing purposes. i am just wondering if it is too much of a project to make the modifications needed. I guess I need to know if someone has done it and if it is worth the bother.
Switching to the l96/gev iv motor will end up costing quite a bit more then the $5400.
Now, my question is could I have cracks in my cylinder heads, that when I add oil when the cylinders are warm that the compression comes back up. Is it possible I have weak cylinder heads? It doesn't oil or smoke that i can detect.
anybody have ANY IDEAS?? I haven't had time to take is apart yet.
Thanks for any thoughts on this, I am heading off to work now.
ive seen a couple cranks have the tone ring for the crank sensor get deformed/break teeth and cause bizarre spark issues. basically the computer loses its place at certain RPMs causing misfires.
