Vacuum / PCV diagram?
Old Feb 28, 2018 | 11:33 AM
Michael Yount's Avatar
Originally Posted by kingtal0n
most performance setups don't use closed loop, or not traditional closed loop.
And most non-performance set ups don't use it either - at wide open throttle. They drop back to open loop.
Old Feb 28, 2018 | 05:33 PM
kingtal0n's Avatar
no computer, whether factory or aftermarket, or person generally would want closed loop at WOT.
Even if I had a wideband system and no transient delay with a failsafe boundary condition I would still avoid using it for multiple reasons, but mainly because it is useless... for most applications.
Old Feb 28, 2018 | 07:25 PM
Which is why none of them or anyone does it, which was said above.
Old Feb 28, 2018 | 07:32 PM
kingtal0n's Avatar
Right, I was adding info to his post to clarify why and how things work. Each post is additional information. Only trolls post just to post, leaving nothing behind except useless words...
ah now you got me doing it too. infectious beast
Old Feb 28, 2018 | 07:48 PM
You just elaborated on what was said already without really adding anything at all. My comment addressed that
Old Feb 28, 2018 | 08:30 PM
Discussion helpful on all fronts....actually, just read an article --- processing speeds and sophistication of algorithms is getting to/at the point where controlling via feedback under all conditions is possible and/or right around the corner. All that being driven by (like it or not) increasing pressure on reducing emissions and fuel consumption.
Old Feb 28, 2018 | 09:01 PM
So the WOT/CL situation will be wide-spread reality soon?
Old Mar 1, 2018 | 05:02 AM
Well, who knows, but capability exists now. Certainly OEM's -- but I doubt the aftermarket stuff will get there soon, but you never know. Hell, Mazda just released compression ignition gasoline engine - 16:1 CR - runs much of the time without/with minimal spark. Go figure.
