Vacuum / PCV diagram?
Old Feb 19, 2018 | 02:16 PM
Cheese Weasel's Avatar
Question Vacuum / PCV diagram?
I'm wondering if anyone has a link, diagram or picture that shows how the vacuum/PCV subsystem on my 6.2L from 2008 should be connected. I've done some searching, but I've found a good bit of conflicting information & data that might be useful if it wasn't for the pictures being absent thanks to photobucket...
For anyone else who might be searching on the same topic, I've found that this page seems to be helpful with understanding how the system is supposed to work, but the images are hijacked as mentioned above, which somewhat limits it's usefulness.
And here's another (Nissan-flavored) page on the topic that I'm working through.
Both of the above examples seem to have decent information, & I'll probably be able to figure out how to hook everything up once I get through them, but I'd really rather have known-good, application-specific data to work from.
Thanks in advance, I appreciate any help.
Old Feb 21, 2018 | 07:52 AM
OK, I'll make the question a bit more general - How does everyone with a Gen-4 engine hook up the vacuum/PCV system? Thanks guys.
Old Feb 21, 2018 | 12:22 PM
There are threads about this on this forum. Do a search and you will find it.
Old Feb 21, 2018 | 02:24 PM
kingtal0n's Avatar
think of the crankcase as a cup. It holds oil in the bottom of the cup. the top of the cup is the valve cover. There are 2 "tops" on your cup, 2 valve covers.
One valve cover allows air into the crank case. If you care about the engine, this side should feed from after an air filter. Or install an air filter of your own here.
The other valve cover is where air is leaving the crankcase to get into the intake manifold. this is where the pcv valve goes. pcv valve is just a "check valve" it only allows flow one direction. You want it to flow INTO The intake manifold when there is vacuum in the intake.
there is more we can with the PCV than just the above, but this is the simplest shortest answer until you ask more specific questions.
Old Feb 24, 2018 | 11:48 AM
Michael Yount's Avatar
Pics of my Gen IV LS3 (6.2L) crate engine run by '08 Corvette ecu.
The engine allows 'make-up' air INTO the engine from the hose that runs between the air inlet pipe and the valve cover fitting. My finger points to the clamp where that hose connects to the valve cover inlet fitting. Note -- 1) that valve cover inlet nipple has an orifice in it that limits how much air can enter; 2) the supply point for that make up air is DOWNSTREAM of the mass air sensor so that the make up air is metered.
Vacuum / PCV diagram?-m4zieu5.jpg
The PCV connection occurs through the little loop of tubing shown in the picture. One end connects to the intake just behind the throttle body, and the other to the lifter valley below the intake. You can see the DBW throttle body motor on the right side of the picture. So metered make up air enters the crankcase through the orifice in the valve cover and leaves through the lifter valley pulling crankcase contaminants into the intake manifold to be used in the combustion process.
Vacuum / PCV diagram?-0mowffr.jpg
Old Feb 25, 2018 | 10:15 AM
kingtal0n's Avatar
Oh nice, I wasn't even expecting somebody to mention the restrictor. Some people deny its existence ...
Old Feb 25, 2018 | 10:27 AM
Nobody around here has....
Old Feb 25, 2018 | 11:59 AM
The OEM covers as well as the replacement Holleys have them. Seen em wid my eyes...
Old Feb 26, 2018 | 09:49 PM
Thumbs up
Michael, thank you very much for taking the time to post that, it helps a great deal, & I truly appreciate your time & effort. That covers probably 3/4 (or more) of what I was hoping to learn.
Old Feb 26, 2018 | 10:00 PM
No Problemo.
Old Feb 26, 2018 | 10:03 PM
Thumbs up
Great info, thank you kingtal0n. I'm sure I'll have a few more questions shortly, when I'm actually hooking the vacuum/PCV system together - but thank you for taking the time/effort!
Old Feb 26, 2018 | 11:35 PM
SheepDog209's Avatar
The cup analogy was perfect. I actually think I kinda understand the pcv concept now. Thanks!
Old Feb 27, 2018 | 07:11 AM
I would add - on most applications, the old school PCV valve is not only a check valve but also a flow restrictor limiting the 'vacuum leak' that could occur when connecting vacuum to the crankcase when a make up air source is present. The check valve function stemmed from days past when gasoline laden vapors downstream of the carb (the vacuum source) could have made their way into the crankcase. Anyone who's ever witnessed a crankcase explosion knows why that's a bad idea -- hence the PCV/check valve
Old Feb 27, 2018 | 10:08 AM
kingtal0n's Avatar
This thread has a bunch of extra info about pcv routing (crankcase pressure and oil control systems) and the purpose of a can
http://www.nsxprime.com/forum/showth...=1#post1909293
Old Feb 27, 2018 | 10:19 AM
-TheBandit-'s Avatar
Michael Yount has it right for the OE gen IV system. To elaborate, the tube coming from the air intake tube to the valve cover is the "clean side" because it normally feeds clean filtered air into the engine. The short u-loop tube from the valley cover to the intake is the "dirty side" because it is sucking contaminated, oil-filled air from the engine into the intake manifold. Even though the lifter valley has baffles and a flow-limiting restrictor, oil will still find it's way through that system and into the intake manifold, so if you want to install a catch can / oil separator you would splice it into the loop between the valley cover and the intake.
It's critical that all the air going through the PCV system is "metered air". It has to be metered because it flows from the clean side, through the engine, and to the dirty side and INTO the combustion chamber. If it's not metered, you will not get enough fuel to cover that air and it will cause the engine to run lean. Therefore the "clean air" inlet should take air AFTER the mass air flow meter to make sure that air is accounted for in the fuel mixture.
Old Feb 27, 2018 | 02:34 PM
I believe the O2 sensors input will correct the lean condition -- however, what the mass air sensor is telling the ecu will be different from the calculated values based on the map sensor --- and it should set off a check engine (with likely several codes) light if the make up air isn't metered.
Old Feb 27, 2018 | 02:44 PM
The O2s will help adjust, but they are narrow band and only work when the engine goes into closed loop. So if you don't meter the PCV air, you may have some issues at cold start and overall performance will suffer.
Old Feb 27, 2018 | 06:38 PM
Agree -- and I'll add, OEM's moved to HEGO's several decades ago to speed up the movement to closed loop....out of necessity as the cold start/open loop time is by far the dirtiest part of the emissions cycle. As regs tightened the numbers, they had to clean up cold starts. As a result, most starts/most climates, cars rarely spend more than 20-30 seconds in open loop before switching to closed. Even a cold start in a cold climate rarely results in more than 60-90 seconds before the sensors are warm enough to move to closed loop. As mentioned before - for a variety of reasons, a big vacuum leak, unmetered combustion air and a mass air/map sensor mismatch on amount of air entering the engine are likely to set off a check engine light and error codes.
Easy to avoid as laid out by a number of us above.
Old Feb 27, 2018 | 09:49 PM
kingtal0n's Avatar
most performance setups don't use closed loop, or not traditional closed loop.
For example I have wideband analog output set for (15.2:1 @ 0.005v, 14.8:1 @ 0.995v)
And there are no narrowbands on the engine.
No point keeping a bunch of narrowbands around unless you have luxury space and don't mind looking at them. In other words, I wouldn't mind having a couple narrowbands for the sake of cylinder balance (one on the right, one on the left, is nice) so you can compare the 4 injectors to the other 4 injectors in theory.
But the wideband, if reading properly, is like having infinite narrowbands, one for each a/f possible
Old Feb 28, 2018 | 08:51 AM
Thumbs up
Wow - you guys have added more & better info than I'd dared to hope for! I think I'm going to save this page to my computer so that I can refer to it in the future. Many thanks guys!!
