Great new fuel system option
as for the plate above the filter I drilled and tapped that for my oil temp sensor.
I know Auto Meter makes a metric fitting for the oil pressure fitting hole behind the intake. I thing someone even makes an adapter for above the filter that is tapped 1/8" NPT they were a little costly though.
Thanks for the reply. That is exactly what I did. I used an adapter to fit the hole where the sensor went and ran a copper tube inside to a new oil pressure gauge. Upon startup I had 70 lbs. of oil pressure at idle. I'm thrilled. Before the new oil pump, lifters, push rods, cam and o-ring tube, I had 15-20 lbs. at idle.
However I have heard a lot of negative input about the 340 pump in the stock tank, and fuel starvation issues under WOT.
The 255 pump and no return, is a simple and effective setup, that when connected to the return less corvette filter/regulator, make for a no hassle, and easy to troubleshoot (if needed) system.
I am still not sure which one to go with....
