L92 + 6L90 wiring and ECU suggestions
I have an L92 out of an Escalade and a 6l90 out of a van that I'm planning to put into my model A Tudor. The engine has Escalade gas pedal, harness and ECU. I'm trying to get my head around what I will need to do to make this work standalone in my car.
Can I just get my ECU reprogrammed and buy an aftermarket harness to hook it all up?
Any suggestions on the cleanest and most economical way to make this work?
Call SpearTech. They do some of the best harnesses in the biz. Tell them what you have and they will steer you in the right direction.
Wow that's a pricy touch! I was hoping there was someone who could suggest a place that could take my current harness and modify it. SpearTech probably make a great product but Just under $1k is a big pill.
For that you get a very professional job done that will "plug and play" . Look around here, there are directions on how to modify your harness to suit.
You either want cleanest or most economical. You CAN have both IF you do it yourself, but someone else will be one or the other.
