1974 C10 - fuel bucket?
What are folks doing with early fuel tanks when they convert to EFI? I plan to run 1 or 2 walboro 450's and like the idea of a bucket bit am unsure what to buy or where to buy it. I know I can probably call Tanks INC but honestly would rather make something work if possible. I also know the pump on a stick method would sort of work but want to steer clear of alway requiring a 1/2 full tank to avoid starvation
I have an ‘85 C10. I’m running an ‘87+ K5/Suburban tank and sending unit. Spectra premium brand. I am using a walbro 255 pump that I attached to the sending unit. Tank goes underneath the bed. I cut the neck off and got one to go straight up to the bed floor.
Originally Posted by brandon6.0
U can get a fuel pump assemblie for a 87 c10. They came with fuel injection and have an internal pump. Would be easy to add 2 pumps if needed.
Makes me wonder if I can use the entire tank as well.
The '87 sender wont fit a '74 tank. Some time in the 80's they switched to the bigger sending unit, that the '87 sender will fit. But, to really do it right you would need an '87 tank and sender since there isnt a fuel bucket, but the '87 tank does have a baffle in it.
i’m using a pump on an ‘87 sending unit for a K5 blazer. It’s not a saddle tank for the left or right side so I’m not sure. I’m using a sock on my pump but the blazer tank is baffled so the bucket isn’t needed. If you want a saddle tank or dual saddle tanks, go with one for an ‘87 pickup. Half tons had 16 gallon tanks, the tanks are also specific for the left and right side.
I noticed they list a "large neck" option and one with out, is that for the sender or filler neck? Also Will my filler neck work?
New tanks look totally cheap enough so why not, if baffled that feels like it will take care of the need for a bucket too.
Probably buy a complete sending unit as well, can I use the sending unit to attach the walboro pumps too?
Sorry for all the Q's, this is my first FI swap so never really felt with this type of fuel system before.
Thanks for the tip, just checked rock auto and see the saddle tank options for the 87.
