Front Sump Oil Pan Questions
Hello all,
I am searching for a front sump oil pan which I have found plenty, but there is one issue I have with a lot of these aftermarket pans. With the exception of one pan, none of the front sump pans have the bell-housing mounts at the rear for the 2 bottom bolts, which in most cases I would be fine with except for I am using a Chevelle bell-house that already does not use 2 bolts.
The one aftermarket pan that has those mounts is the Sikky pan, but it is pricey and I am attempting to do a $0 LS swap on my E34. The GTO pan would also work, but I am trying to find something as compact as possible. Does anyone know of a good front sump pan that still utilizes the rear bell-housing mounts?
