Ls swap new edge
Worst case buy some Aeromotive or vdo or whatever gauges and replace the guts of the Mustang cluster.. ?? I've done small clusters in cars where the OEM wasn't available, was a fiddly project but I did it on a desk table while binge watching tv.. Long as they use needles your good, just swap the guts of the gauges and build a new harness on the back.
Ford harness’
I have been reading up on your post, I understood quite a bit as I’m running almost the same setup, we’re you able to eliminate all your ford harness’ or were there any harness’ and/or ford modules you still had to use?
On a side note I've done 4 New Edge swaps and am currently doing a 96 Sn95 swap and at this point I'm confident I could use the factory modules to control just about everything at this point especially if you run a Holley. No added relays no hacked up wiring just some time depinning and swapping stuff over. I like these cars and am pretty comfortable with them at this point.
