Ls swap new edge
I'm going with a gen 4 5.3 with a 4l80e.
I already have a tubular k member, so i know the obvious, need motor mounts, cross member, ecu, etc.
I have read someone using the stock ford driveshaft on a 4l60. I have a aluminium ford racing driveshaft and wonder if i can use it on this setup or should i get one built.
I think one of the things I'm going to spend a lot of money on will be the holley efi domimator for the simplicity and being able to tune it myself.
I really want to use my gauges, its a bullitt and the cluster is nice and want to keep it, what are my options on that?
This will be a turbo build, can anyone direct me on manifolds they've used or will I have to get some made.
As far as the lights and ignition read a few forums that it'll work like it used to. Any pointers on that?
Still in the process of pulling everything out, will post pictures as I go along. Any advice or other similar post would be greatly appreciated.
4l80e will absolutely work, and depending on the K-Member and the mounts being used will depend on how much hammer you use for the trans tunnel. Stock K member, holley engine mount plates and 4.6 motor mounts will fit the 4l80e just fine in the OEM trans tunnel.
Stifflers makes a crossmember that uses the OEM trans crossmember mounts that is listed as a t56 crossmember, but I've seen someone use it for the 4l80e, just cannot recall the member.
I have heard the mustang driveshaft will work and is the correct length, it just needs the proper yoke and u joint. I believe the mustang drive shaft uses a 1330 u joint just like the driveshaft behind the 4l80e/4l60e. Research this as the u joint size I listed may or may not be wrong.
Holley EFI dominator is a great looking product, but if you are comfy with computers and numbers, you can get the HP Tuners pro suite for less than half and do it yourself with the OEM PCM. You cannot go wrong with either, just depends on what your wallet will allow. Also, re-wiring the OEM LS harness to stand alone isn't terribly difficult, but should definitely be taken seriously and slowly. I see so many people pulling the wrong pins or swapping the wrong wires entirely too often. Just take your time and read, read, read. http://lt1swap.com/wiringharness.htm will be your bible for the stand alone harness creation.
Gauges: You can use the stock stuff, but depending on the year of your mustang, the canbus system will need to be wired in parallel to your 5.3 PCM/dominator PCM. The GEM, PCM, CCRM and FPDM all are connected. The GEM controls alot of the extras like multifunction switch on the column for blinkers, windows, locks, lights, etc. CCRM controls power to the FPDM, and the FPDM controls the voltage to the fuel pump based on the fuel pressure. eliminating only one could cause issues, eliminating all will just be a headache. (I eliminated all, kept everything super simple like late 70's early 80's wiring. Just the necessities.)
Some guys use the stock manifolds flipped, cut the OEM flange off the collector and weld a v-band flange on. You can also buy super cheap forward facing turbo headers off ebay, but spark plug clearance is **** from what I've seen, and eliminates the possibility of using stock accessory drive. This just adds to the overall cost of the swap, moderately annoying, but can be easily fixed with new accessory mounts from multiple manufacturers.
Referring back to Gauges, if you have the canbus setup and you remove the GEM, ECM, Etc. you will lose the ability to control the windshield wiper switch as it works on specific OHM readings going into the GEM. Turn signals, lights, etc. all have signal wires that allow them to be powered once the GEM sees power and the correct key. GEM houses the anti theft garbage.
I've come to find that I'm into this swap on my 03 mustang for alot more money than expected. Which is fine, but unexpected. I also did too much too soon. Wiring in my case has been troublesome as I'm deleting all of the modules and going back to good ole' switches and relays for everything.
If you want to get it done fast, change/update the things that are absolutely necessary first, add fun stuff next.
If you don't care about time to completion, then do whatever you want. Just realize there are so many hidden costs and extras that you will always want and if you take your eyes off the prize, you'll end up on jackstands for the next year or so like me lol
If you want that kind of power please don't even consider a 4l60 just go right to the 4l80e. I hammered my tunnel in a little bit but nothing excessive, just a few spots like the shift linkage and electrical connector. I gave a few wacks around the rest but that was just for safe measure it actually fit like it was meant to be there. I used a 1330 slip yoke from denny's driveshaft and used my stock drive shaft it fit perfect. I used stock 4.6 motor mounts and made a set of adapter plates. If you google it you can buy some but for the cost I just made my own. I think UPR has a set. My trans crossmemeber I used my stock gt one and cut the mounts off the body and just welded them a little farther back and drilled out the crossmember. Fit very well.
To get the gauges like Andler2008 said youll have to strip your ford harness and basically feed the ecu everything it needs to think the engine is running. You'll need converter boxes for the speedo and tach to get the right signal. Fuel and voltage works regardless. Oil is actually a dummy 6psi switch from ford so that's not difficult. And coolant temp you can use your old sensor and just install it in the rear passenger head with an adapter or tap it. If your looking for budget friendly this can get very costly and I abandoned this after a few months of driving with no gauges. I installed a set of 2000 Camaro gauges. They look decent and work perfect.
I don't know much about the holley system but I think that hptuners and a stock computer with a reworked harness is the way to go. It'll control your trans instead of having to look for a separate controller which will add up for cost. The investment of hptuners was a big expense for me but I'm glad I did it because I've used it on my 2 cars and a few friends.
I'm running an ebay gt45 turbo with stock manifolds cut with 2.5" vbands installed. Turbo placement and exhaust routing was a pain. There isn't a ton of room on these cars and I have a stock K member so that didn't help. I planned most of my exhaust without my cooling system in so I had to redesign a lot after so I wont make that mistake again. As far as cooling goes I'm using the stock gt radiator and fans. No cooling issues so far. I've got a ls2 intake manifold, stock truck throttle body, decapped truck injectors, stock truck water pump, stock truck alternator. I used my GT powersteering pump with a bracket I made but I keep throwing the belt so I'm probably going to go electric that's my new project right now.
Everything works on my car as if it was just key on engine off. Lights, signals, heat (a/c is disconnected), wipers etc. If you want anymore info I'm happy to let you know what I've done or tried or what didn't work. I love the new edges so I love seeing them get repowered!
honestly i sort of wish i did a TH350/400 instead since i am not goign to be street driving mine at all the OD isnt really needed.
im thinking about hitting up a junkyard this weekend and looking for an electric power steering pump that i can use to keep power steering without the pulley driven pump.
The lazy/easy way to swap a '99-04 Mustang is to just unbolt and remove the main engine wiring harness, disconnect and remove the instrument cluster (which is integrated with the factory ECU) and just add wiring for your own instruments, etc. If you can find room, or drill your own holes to run your wiring harness, that will probably work fine.
The slightly more ambitious way is to just delete all of the wiring related to the factory ECU. On my own car, I deleted the CCRM, the Ford ECU, and the entire wiring harness that goes through the passenger's side fender area. I only have one wire passing through the grommet in the passenger's side fender--the right turn signal/parking lamp. I seem to recall having to do something to bypass a neutral safety switch on the transmission (which runs through either the main engine wiring harness or the CCRM, don't remember), but that was basically just shorting two wires together so the ignition switch just directly triggers the starter, rather than running through all that stuff.
I'd definitely get a plan in place before you just sell stuff. The 50-100 bucks for the ford pcm shouldn't be make it or break it. Just my 2 cents though.
So to be clear I can remove just my Ford engine control module/wiring harness and power the oem engine bay fuse box and not have any issues with vats only losing rear defrost (idc about stock gauge cluster).
also did you ever get a/c working? I’d like to get ac working controlled by the gm pcm, but still using factory ac controls. all I’d need to get this to work theoretically is a ac request signal/wire but can You even get that from the Ford bcm?
As for the factory A/C, I think it goes through the CCRM and the PCM, I can't remember if the BCM did anything for it. I never got around to hooking it up but what I came up with was that the ford outputted 12v to trigger the A/c. You can use this to trigger whatever a/c unit you have but I believe you have to feed the same 12v to the GM PCM to let it know that the A/C is on.
I think there is a bit of confusion due in my part to my wording, I don't plan on to use the ford pcm for anything. I want to use the gm pcm to control the A/C, but i didn't know if i could get 12v ac request from the bcm but if it works with the pcm it might be fruitless.
But i've had an idea to cut the ccrm and pcm out of the equation, I could use one of my 12v switches from my switch panel as the 12v request signal to the gm pcm to kick on the ac. Then just use the factory controls for blower and the blend doors, do you see any reason this would not work?
On a separate note what all is affected by removing the ford pcm and powering the factory fuse block and leaving everything else? I know you lose factory gauges (as said earlier idc about them) rear defrost, stock fuel pump control (not needed), the ac trigger stuff, and anti-theft. This is all i have been able to gather is there anything affected that i'm missing, i don't want to come across a major surprise lol.
I'm newer to swapping and trying to figure stuff out so thank you for letting me rack your brain.
Long as they use needles your good, just swap the guts of the gauges and build a new harness on the back.
