Duel to single fan wiring
As for wiring with the AC if you run a trinary switch instead of a binary, you can get away with a single relay since you can have the trinary send a ground to trigger the relay just like PCM does. If you want to use just the binary switch then you will need a second relay to reverse the +12v signal that used to trigger the compressor clutch.
