65 CJ5 LS Swap
I'm doing a full rebuild to a 1965 CJ5. New custom frame, rebuilt axles, new body, and of course an LS motor. Engine is a 2007 LY5 5.3l. Bottom end is stock with less then 50k miles. Cam is a GM LS9 cam with rebuilt 799 heads and Trailblazer SS intake. We used a Corvette crank pulley, water pump, and all accessories to keep it as short as possible.. Should be an honest 400 hp engine with no drivability issues. Transmission is an SM465 with a Dana 18 transfer case and Jeep Dana 44 front and rear axles with 3.55 gears and Chevy truck disc brakes. The pre-72 CJ5s have a shorter front end so it's a very tight fit, but it does fit.
1965 CJ5A Tuxedo Park Mark IV full restomod rebuild
- 2007 Silverado 5.3l LY5 short block
- DOD delete
- LS9 Camshaft
- 799 Heads w/ uprated springs
- TBSS Intake
- F-Body Oil Pan
- FiTech Standalone LS wiring harness and ECM
- FiTech 92mm Throttle Body (DBC)
- Corvette Damper and accessories to minimize overall engine length
- Advance Adapters in-frame headers (shortys)
- Dual Exhuast with Flowmaster 10 mufflers
- Throttle Down Kustoms early CJ5 frame
- MD Juan new tub, fenders, and windshield frame
- Dana 44 front and rear axles from a J-Truck with Quadratrac
- YJ leaf springs with a front shackle reversal (OME 2.5 inch lift springs)
- 4 wheel disc brake conversion
- New in frame 15 gal fuel tank w/ Walbro 255lph in tank fuel pump and Corvette style regulator/filter
- Western Turbine wheels powder coated black
- New Bestop soft top and bikini top
- Original Tux Park front Bench seat and bestop rear seat
- Ron Francis full wiring kit
- Warn 8274 winch
Still need to change the water pump.
Had to do a 1 inch body lift to clear the SM465 and Dana 18.
Mike
Mike
Mike
