Rules On Coolant Reservoir Placement?? HELP!
My questions focus mostly on how high the reservoir needs to be mounted. Is there a rule on it's placement? Since this is a '70 truck the engine is already a little bit lower than the radiator. Please give me some pointers on where to place this thing. I don't want problems with the engine over-heating.
Things I've thought of;
Does the outlet on the reservoir need to be higher than the heater hose connections/outlets on the water pump? If so, how much higher? When I look at factory trucks, the reservoir sits on the passenger fender really high. I "think" I can make the reservoir the highest point of the cooling system, but it is going to stick out like a sore thumb if I do so. Can I just mount it so that the cap on the reservoir is the highest point?
Any advice would be appreciated.
I'm still not 100% sure where my placement should be in height relative to the engine. I guess I will just buy & install the Cruze reservoir, and place it as high as I can in the engine compartment in an unobtrusive location, and then testing by driving it.
Attachment 713890
Thanks too for the information on the placement of the reservoir. My problem lies in the fact that the TOP of my radiator is perfectly level with the top of the core support. So, I would need to place the reservoir HIGHER than the top of the radiator core support. I will have to check and see if I have enough hood clearance to do that. Due to the shape of the hood, I believe I can do it.. Man is it going to be butt-ugly though when you raise the hood and the reservoir is the HIGHEST component sticking out of the engine compartment.
This is where rat rodders sometimes place a PBR can or Jack Daniels bottle to collect any overflow. If you are going to a track, then you are required to have a catch can. As for the coolant steam vent you can tap the WP (well documented) or use a JTR (Jags That Run) inline "T" off the upper rad hose.
FWIW the stock C10 radiator works just fine. I've been running for a few year w/o issue. Even in Dallas TX heat for a year with no problems at all. Mechanical fan as well. Don't get sucked into the $$$ vortex of needless LS spending. LS engines are very efficient.
The newer systems include the reservoir in the pressure system. Even then it can be below the radiator top. In this case the radiator has no cap. The pressure cap is on the reservoir. My 2013 F150 is set up exactly this way
So, it really depends on what radiator the OP is using...?
If the pressurized reservoir is BELOW the top of the radiator the 'air expansion gap' will be the portion of the radiator that's higher than the top of the reservoir - you won't be able to fill the radiator all the way to the top. Every pressurized reservoir system I've seen has the reservoir cap as the highest point in the system.
