C10 ls1 5.3 swapped no start
I have an ls1 swapped into a C10.. it cranks but will not start.. I have constant 12v power, I'm getting power to the coil packs I'm getting rpm reading on hp tuners while cranking any suggestions for me would be great thank you again for your reading
grounds. There are usually 2 grounds rear passenger head behind intake. Sometimes one on front passenger head. And sometimes on the block either driver or passenger side near the front. I had a ls3 that had a loose ground and wouldn't fire the plugs. I had 12v at the coil harness but no spark. Tightened ground car fired right up.
Definitely check grounds. I swapped out the 4.8 in my girlfriends Silverado and put together a heads/cam LS1. It would turn over but wouldn't actually run. Turns out I didn't connect one of the grounds. Connected it and it fired right up, didn't skip a beat.
