Is my radiator causing my overheating? Regarding the rows in the radiator
Old Jul 31, 2018 | 09:43 PM
APillow's Avatar
I might be off depending on your setup, but sometimes a fresh radiator cap does the trick.
Any kinks or hard bends in the hoses? (hose collapse)
Old Jul 31, 2018 | 09:50 PM
Originally Posted by Michael Yount
I wouldn't order a new one --- without at least trying to clean the old one. Cap off the openings and get some CLR in that thing; rinse, repeat. See what you can get out of it. Hell, we may be missing something.
This.
Also, how is your coolant crossover line ran? Sounds like you still have air in the system.
Old Jul 31, 2018 | 10:18 PM
Michael Yount's Avatar
Is it possible to have a belt wrap problem where the water pump is being driven the wrong way?
Old Jul 31, 2018 | 10:47 PM
If you could, send in a diagram of how your belt runs around the pulleys. This will answer Michael's very valid question above
OR, answer this- If the ribbed part of the belt is driven by the crank, does the BACK (non-ribbed side) of the belt ride on the water pump pulley? If so, the belt is driving the water pump correctly
Old Jul 31, 2018 | 10:56 PM
Did it overheat before the gasket work?
Old Aug 1, 2018 | 12:24 AM
driveability's Avatar
Unless I missed it, I would make sure you have an appropriate alternator. I always use at least 150 AMP unit and Spal fans !
Old Aug 1, 2018 | 01:55 AM
jmd's Avatar
jmd
You're looking up top. More corrosion will show down low.
If it looks corroded down low, the tubes are blocked too.
Aluminum sheds heat to air better than brass.
One-row radiators flow more air than 2, 3, or 4 rows. If you can find an OEM size to fit your Chevelle in a one-row aluminum, it is guaranteed to outperform your antique clogged junk and will usually be cheap. My last stock replacement one-row lasted me 14+ yrs w/ a SBC in 120+F temps.
Old Aug 1, 2018 | 08:35 AM
TXjeepTJ's Avatar
This.
The steam vent port goes into the radiator at a port a little bit below the filler neck
No kinks or hard bends, the radiator cap has been replaced, as I thought that was it to begin with lol
I am 99.99% sure I have it routed correctly, but will check again when I get home
99.99% sure it's right, because I always have to look up a picture of how it is routed when I install it. The non-ribbed side is definitely what is touching the water pump. I will double check all of this when I get home though
Of course, I never had the engine running before doing the new head gaskets - bought it from a salvage yard and installed the new gaskets
Since it is doing this at highway speeds, it would rule out the fans being under powered. Once I get it to stop over heating on the highway, then I might know if the fans are under powered lol if it over heats at idle still
I might be pulling the radiator soon, will be able to examine it more
Old Aug 1, 2018 | 09:39 AM
ls1nova71's Avatar
If the previous owner ran Dexcool in the radiator, it very well could be clogged up, that stuff isn't good in most swap situations. That said, the top part of the radiator doesn't look too bad to me, but like the others have said, it could be clogged down low.
Old Aug 1, 2018 | 10:11 AM
TXjeepTJ's Avatar
Prev owner definitely ran DexCool in it, the residue I wiped off inside of it looks exactly like the residue build up you see in DexCool filled Silverado's coolant tanks
Old Aug 1, 2018 | 10:51 AM
APillow's Avatar
Did the radiator work fine before the LS swap?
Also on the thermostat issue, I know you changed it at some point. But from my experiences, it is best to stick with a GM / AC Delco factory part. Or boil it on the stove to ensure that the T-stat is opening fully while monitoring the water temp with a candy thermometer.
... Really the LS is more efficient than a similar SBC or BBC, so cooling shouldn't be that hard. Perhaps monitor with an infrared heat gun or mechanical gauge to ensure the dash gauge is reading correctly (bad ground?). At 230F when you stop that thing should be gurgling in pain before popping water out the overflow. Also oil pressure would start reading lower as coolant temp increases.
I did not catch the answer, but yes as others have said, you need to ensure the steam vents are routed properly to get the air out. Water pump mod or JTR inline adapter both work well.
Really bad luck would be something is wrong internally causing the heat build up...
Old Aug 1, 2018 | 11:11 AM
  #32
TXjeepTJ's Avatar
@230 coolant was boiling out the radiator cap and into the overflow
Not sure if the radiator worked or not before the swap. I bought it used, been having issues with it ever since.
I'm about to order the JTR inline adapter. Maybe where I have it plumbed into the radiator right now isn't good enough. The stock thermostat did the same thing, would slowly gradually overheat, same w/ the new thermostat (even though it isn't AC Delco)
Old Aug 1, 2018 | 12:48 PM
  #33
truckdoug's Avatar
so you did verify neither head gasket is on backwards? I have seen that twice now.
most LS t stats have a tab to keep the bleed valve at 12 oclock position, but it's good to verify it anyway.
next on my list would be burping the cooling system. fill the motor with coolant from the outlet at the top of the water pump. Put the hose on and fill the rad and hoses.
you might consider buying a vacuum filler kit. its a must of you mess with newer cars.
Unless you rad is totally blocked, even the tiniest radiator will cool an LS. We have used little scirocco and civic rads to make room for turbo plumbing and they stay plenty cool.
Old Aug 1, 2018 | 02:25 PM
  #34
TXjeepTJ's Avatar
Yeah, I posted above stating that I saw the driver's side head gasket had the metal tab near the front of the engine, which is where it should be. I was unable to see the Passenger's side though, but will be looking again once I get home to see exactly where the tab is on that side.
The thermostat on my water pump is built into the filler next, so I'm not able to orient it a certain way
I bought one of the radiator funnel deals, ran the motor a good bit, reving/squeezing and getting all the air bubbles out. Was pretty certain I got all the bubbles out
Old Aug 1, 2018 | 06:30 PM
  #35
TXjeepTJ's Avatar
Checked both sides of the engine and the head gasket tabs that are exposed are both closer to the front of the engine, which confirms they are correctly installed
I also checked the belt routing, and it matches the correct routing
Old Aug 1, 2018 | 06:41 PM
  #36
If you’ve got an infrared temp gun, bring the car up into the 200-210f range and then shoot various parts of the radiator core. If clogged/deposited-up, you’ll find significant hot/cold spots. Otherwise there should be a pretty even distribution of temp drop from the hot side to the cool side.
Old Aug 1, 2018 | 07:11 PM
  #37
TXjeepTJ's Avatar
Good idea!! I have an infrared gun too
Old Aug 1, 2018 | 08:00 PM
  #38
Have a buddy with a 5.0L converted Volvo - had the stock 33 year old diesel radiator in it. Had intermittent overheating problems once he got the 5.0L running. His IR gun showed the bottom third of the radiator was "cold" when shot with the IR gun. Completely clogged. I had mentioned he ought not to trust a 33 year old rad....
Old Aug 1, 2018 | 10:28 PM
  #39
TXjeepTJ's Avatar
well, I just realized the idea of using the temp gun on the radiator will require me removing the condenser and my intercooler.. which I really don’t want to do as my time is very limited to work on the car. At this point I wouldn’t mind spending the money on a new radiator even if it isn’t the problem.
A question for anyone though - I notice that If I turn the heater on when the car is at 220 degrees, the temp will drop down to 190 within a couple minutes. Could this be even more proof my radiator is complete crap??
Old Aug 2, 2018 | 05:53 AM
  #40
It’s certainly proof that the heater works!
