Vss settings
Old Aug 11, 2018 | 06:55 PM
Mrngwoodstewie's Avatar
Default Vss settings
so my problem is im hitting my speed limiter. Ill be going maybe thirty and e38 on hptuners says like 160
any help would be apreciato!
Old Aug 11, 2018 | 08:37 PM
8.Lug's Avatar
This is a PCM problem, you’re in the wrong place.
Old Aug 11, 2018 | 08:43 PM
What 8.Lug DIDN'T tell you is this should be in PCM Diagnostics and Tuning.
Old Aug 11, 2018 | 11:13 PM
Good call! I should of posted there. So we didnt figure out the math yet; but thought to just verify by maxing out the speed limiter, and it runs like a bat out of hell now. Soo I think its safe to say its a vss speed limiter problem. The pcm is still pegging out at 158mph though. I at least can drive the speed limit now.
It really made a lot of sense once we could data log. I was so confused thinking what kind of CEL would ignition cut at a pre determined speed. Once he pointed that out; I was duhh!
but I still would like it to be on and thats why I thought someone that did a conversion like this could say its either a different option on the signal or its a pupse per rev or something. I think I may be better suited in the pcm sub forum though. Thanks! As always though.
