5.3 temperature question
I'm taking it to a tuner next week to get it dialed in and hopefully find my engine code problem.
http://brazeauracing.com/mustang/airdam.htm
My car has an OEM device that many refer to as a "splash pan" -- although it's main purpose has nothing to do with preventing splashes into the compartment. It attaches below the radiator support and is the full width of the front frame rails (29"). It extends all the way to the engine/suspension crossmember. It's there to create low pressure below the engine at the back of the engine bay. This effectively "sucks" air across the radiator at speed and the the air leaves the engine compartment below/behind the crossmember.
With my 71 C3 LS1 swap running a 160 degree stat and a big griffin radiator I was lucky to hit 180 degrees on 80 degree day.
Also you will know when the thermostat is open if you take off the radiator cap and see good flow of coolant coming out off the radiator fins. Flow should vary as the rpm go up and down.
My factory/crate LS3 came with a 187F t'stat (checked with thermometer in a pan of coolant on the cooktop) located on the inlet side of the engine. Under cruise with enough air moving over the radiator to keep the fans off, the temp sensor in the driver's side head sensor (the one the ecu uses) is 196/197F - read off the OBDII port with an app. When it's 30F outside, that may drop to 195F; when it's 95F I may see 198F. Clearly there is enough radiator capacity and air flow to reject enough heat to hold a constant temp regardless of the ambient temps. My fan controller is set to maintain a 203F operating temp (variable speed controller). When I'm going slowly enough that the fans are running, the head temps are in the 202F-204F -- again, little variation with ambient temps. The variation that does occur is that when it's warmer, the t'stat is open more; when it's cooler, it's open less; when it's warmer the fans run more often and faster; less often and slower when it's cooler. I use a Howe Racing 2 row (1" rows) aluminum unit - about a 23x16 core. Fans are SPAL dual 11" fully shrouded with flaps that allow air to pass through at cruising speeds when fans are off.
Someone noted earlier in the thread -- if you're using the unmodified factory ecu to operate your fans -- your engine temps with fans on will be quite a bit higher than my spread above. I may have it wrong -- but memory says the folks at PSI Conversions told me that my 08 Corvette ecu turned on fan one at 226F and off at 220F; fan two at something like 232F, off at 226F. Clearly those temps shouldn't cause a problem with the engine as they were OEM settings. But I wanted a tighter operating band than the almost 40F between 195F and 232F.
Your cooling is "OK" for now, considering the OEM operating range and ambient temps, but I'd consider sealing everything off including any holes in the core support and looking for ways to increase pressure in front of the radiator and reduce it behind. A magnehelic gauge is a cheap and effective way to gather data and troubleshoot. Here is some good reading material (check parts 1 and 3 for even more info).
Here's part 3; it mainly addresses hood vents, but still has some good info.
I should also add that I started doing delta-P tests, but haven't gotten a chance to fully explore the effect that closing up my swiss-cheese radiator support and underbody modifications would have. I did close off the underside of my cowl hood based on a measured 1.5(!) inH2O on the freeway.
