Ls1 Auto-Acceleration??
Old Oct 7, 2018 | 01:03 PM
fozz71's Avatar
Default Ls1 Auto-Acceleration??
Recently purchased a 70s muscle car with an LS1 swap- the car runs great but auto-accelerates at times. I can be cruising at 30mph and it slowly creeps up within a few blocks to 35, then 40 and so forth.
Can anyone help me figure out why it auto-accelerates? I have sealed the EGR valve and installed a brand new PCV hose set. The car runs without a MAF sensor, it was turned off by the shop who did the swap.
Thanks,
Jim
Old Oct 7, 2018 | 08:57 PM
fozz71's Avatar
Default Ls1 Auto Acceleration??
I recently bought a muscle car with an LS1 swap- the car runs great but auto-accelerates at times. I can be cruising at 30mph and it slowly creeps up within a few blocks to 35, then 40 and so forth.
Thanks,
Jim
Old Oct 7, 2018 | 09:03 PM
Which car, which ECM, which tranny, and who tuned it?
Old Oct 7, 2018 | 09:50 PM
fozz71's Avatar
Default Auto accelerate
2002 Camaro SS, trans is a 4L65E automatic and not sure about the ECM, tuned by Sal’s Shop in Los Angeles.
How can I determine the ECM?
thanks,
Jim
Old Oct 7, 2018 | 10:29 PM
If the ECM is OEM someone here would know which one that is.
2002 Camaro SS came with LS1, so why do you call it a muscle car swap?
Old Oct 8, 2018 | 12:51 AM
8.Lug's Avatar
Have you tried letting off the gas?
Old Oct 8, 2018 | 06:36 AM
fozz71's Avatar
Because the motor is now in a 1970s car.
Old Oct 8, 2018 | 06:47 AM
99 Black Bird T/A's Avatar
Might check for vacuum leaks. PCV system, brake booster & intake manifold. Had an experience when an intake manifold had three bolts loose, and the PVC & brake booster hooks ups were crossed.
Also LS1's are about 20 years old in some cases and those intake manifold gaskets can get so they don't seal well and need replaced. Be careful tightening the intake manifold bolts if you retorque them.
Old Oct 8, 2018 | 08:09 AM
NHRAFORMULA00's Avatar
Does the idle drop down once you come to a complete stop? If it does then it is in the tune. Too much ignition timing from just off idle.
Old Oct 8, 2018 | 02:25 PM
fozz71's Avatar
Yes, it idles down at a stop and also if the car is just in "park" or "neutral" - once I shift into "drive" the power begins.
Old Oct 9, 2018 | 09:35 PM
LLLosingit's Avatar
Have you been huffing paint?
Old Oct 9, 2018 | 10:03 PM
I believe he prefers glue...
Old Oct 11, 2018 | 09:15 AM
dogger's Avatar
does the car have cruise control? I had a cruise control module act up causing a similar problem even when not on or using. I think something in the cable was snagging but I replaced the module and cable and it was fine after that.
Old Oct 12, 2018 | 05:51 PM
fozz71's Avatar
No, no cruise control.
