97 2 door race jeep
This is my S10 i have a build thread on it also.
all tucked in for winter.
here is the jeep before i got it. it used to be a 4.0 with a supercharger from a thunder bird. Was a fun jeep until trans started having issue and it had a ton of blow by. My Buddy pulled drive train and was planning on a ls swap but never got around to it so i picked it up pretty cheap. Engine bay already cleaned up and spray painted with the same stuff i used on my blazer.
How it looks now.
got the chassis wiring laid out
DId some inspection on my spare 6.0. heads needed some valve lapping from being rebuilt. these heads were on my blazer when i bought it years ago. wish i knew what springs it has in it
some late night therapy
heads are all sealed now
Got this 80e and np241c cheap but bell is wasted so got a th400 to run
the output on the Th400 is about 1.25" to long so will be trimming this soon. i want to find a NP 242 cause they have the full time 4wd with a good 48/52 tq split. Looks like i could use input shaft from the 241 but need to do some research on it. will be redoing the brake lines this week and ordering mounts. i got a nasty SNL NA cam for it and ls2 intake. I really want to boost this thing tho. we will see. swap headers are about the same price as a turbo.
I will be running a micro squirt set up on this one. i already have the tuner studio ultra and mega logger HD and dont wanna buy Hp just for one jeep.
Stay tuned and if any one have any experience in these swaps hook me up.
i hate brake lines and didnt care if they looked pretty lol
Waffle hanging out
Found a new place to chill while in the garage with me hah
That bass boat flake tho
hoping to have brakes all done this weekend. mounts will be ordered and maybe t case mated to trans.
MOunts
Dash is out. going to add a fuse block for accessories somewhere under dash
Hopefully have engine and trans in place tonight.
Ten years ago the Jeep tach and the signal from the LS1 computer didn't play well together. So I mounted a smaller aftermarket tach behind the windshield A pillar. Also I didn't like the stock oil pressure gauge. Mounted the oil pressure gauge right above the tach.. Can't see either from the outside of the vehicle.
I think Novak now makes some type of conversion harness so the stock tach works. All the other gauges work as stock.
thing hangs kinda low
working on the driver side manifold to build a cross over for a log style set up
basically making this out of scraps i have laying around lol
This was a down pipe from an EVO
Borrowed a buddies CX racing twin turbo kit from a GTO. could def make this work but the headers alone are 400. Thats out of budget for me but just incase some one was wondering what fits. those will fit nicely.
Im trying to see how low budget can swap a XJ. so far
300 for jeep
600 for 6.0
200 for trans and np241
250 for mounts
USing stock XJ cross member. will need to drill a could holes in it once i get good and centered. The Front drive shaft yoke is pretty close to the cross member so might have to clock it or trim the x member. heading to junk yard maybe next weekend and find a dana 30 and a 4wd shifter. Buddies hooking me up with a SNL cam and some good springs, LS2 intake and rail with some ID1000s and a DW 340 fuel pump. The cam isnt IDEAL for boost but we will see what it does with one GT45 or S366 or s475.
Hopefully knock more of the log and cross over out tonight. need to order some V bands and a t4 flange.
Chain comparison. 242 on the left and 241 on right
Few differences between the two
242 about ready to be sealed up.
Main reason i went 242 is to keep the stock yokes on front and rear and also the speed input. i want most of the factory gauges to work.
I should have it fully assembled after i get some new seals n maybe snap rings. Need to chop output on trans still and freshen it up. Should have cam and springs in a week or so installed and will get engine back together shortly after. i ready to do some AWD burnouts lol
