Engine swapped cooling system question
Old Mar 28, 2019 | 11:49 AM
  #41
stevieturbo's Avatar
Relatively speaking, pressure under normal circumstances is low in there, it should not need a bead at all. Although it is of course good practise.
Old Mar 30, 2019 | 07:26 PM
  #42
Monkiejohnson's Avatar
With a system pressure of no lore than 10psi I figured
it wouldn’t have been a problem but with the upper hose popping off for the second time I gotta change it up.
Old Mar 31, 2019 | 03:28 AM
  #43
There is absolutely no way a correctly installed hose should be popping off at 10psi. Nor 20psi...and not even 30psi.
Maybe around 30psi I'd say a bead would be starting to become very important. But not at all at 10psi.
Old Mar 31, 2019 | 10:20 AM
  #44
Is the hose ID a bit larger than the neck it goes on? If so the clamp would have to be VERY tight to hold it on at even 10 psi.
Old Mar 31, 2019 | 10:32 AM
  #45
One would hope the correct size hose is being used.
Old Mar 31, 2019 | 10:33 AM
  #46
One would, but is that always the case?
Old Mar 31, 2019 | 10:43 AM
  #47
No...but if not, they deserve to have hoses coming off etc. It's not difficult to get it all right.
Old Mar 31, 2019 | 10:54 AM
  #48
Agree here too! And I have a feeling the OP got most if not all correct, so it IS a mystery as to the hose slipping off at such low pressure.
Old Mar 31, 2019 | 11:35 AM
  #49
Could be as simple as clamp incorrect, not tightened properly etc.
Or maybe there is more pressure in there than he thinks. I assume the "10psi" is guessed rather than measured ?
Old Mar 31, 2019 | 11:43 AM
  #50
Good points, all!
