1974 C10 DBC throttle
Old Dec 1, 2018 | 08:09 AM
epfatboy's Avatar
Default 1974 C10 DBC throttle
what throttle cable and bracket is everyone using for this swap? I have a gen 3 truck swap going on and it's time to hook up the throttle!
Old Dec 1, 2018 | 09:44 AM
truckdoug's Avatar
stock DBC truck cable works great!
Old Dec 1, 2018 | 11:03 AM
brandon6.0's Avatar
Yep stock dbc silverado cable. May have to bend the gas pedal arm slightly for more pull for wot blade opening. Other than tht they work perfect.
Old Dec 1, 2018 | 01:42 PM
epfatboy's Avatar
off to the junk yard! Thanks for the tip.
Old Dec 3, 2018 | 03:05 AM
tfi racing's Avatar
Grab a few while you are there, a good general throttle cable for many uses!
Old Dec 3, 2018 | 06:00 AM
gofastwclass's Avatar
That only works if the guys in your area are smart enough to not cut, break or manhandle them while taking other bits they need. WTF.
Why do people destroy what they don't need just to get to what they do? Doug did a video on this very thing.
Old Dec 3, 2018 | 09:12 AM
truckdoug's Avatar
yeah that stuff irks me to no end. I understand some of it, not bringing the right tool or something. But a see a lot of plain malicious destruction. No respect for recycling, other people's property
I went to get a truck harness to thin for the squarebody a couple days ago. 4 LS powered trucks...all of them the harnesses were shredded to bits. I mean the connectors are easy to remove, why do that? It's almost harder than just unclipping it all.
Old Dec 4, 2018 | 01:10 PM
epfatboy's Avatar
yep, truck after truck had there cable cut so that the yard can dump the engine/tranny out. Wonder if the yard owner would approve. But then again I walked out of there with 2 cables for $5 so maybe cutting versus un-hooking was worth the $2.50?
Old Dec 4, 2018 | 01:56 PM
truckdoug's Avatar
haha man, having worked at a not-open-to-the-public junkyard (1st job) I can say that the dismantlers are usually paid near or below minimum wage (under the table) and it's literally the only job they can get (my mom did the books there, i was 15 and liked cars) and there is NO chance of excelling, moving up or even having your hard work recognized in the tiniest way.
at least as a fast food place someone will occasionally say thank you or have a nice day
so when I see an engine at LKQ that looks like it was pulled from a truck by a fred flintstone riding a brontosaurus, i totally get it
