MAF sensor alignment to coupler
Old Dec 2, 2018 | 06:00 PM
Vetteman61's Avatar
Default MAF sensor alignment to coupler
Hello all,
The MAF sensor I ordered has a small tab which prevents me from sliding the coupler all the way up against the largest part of the sensor body, as pictured below (tab is on top, the rectangular piece to the right of the circle. Also, what is that circle for?).
When I do install the coupler, it looks like this. Note the gap. These are 4" to 4" couplers, however this side of the MAF is smaller (the other side is the full 4"). The couplers came with a small rubber piece to step down in size and the clamp is able to tighten down the difference. I have read on the forum that others have used this technique successfully.
Here are both sides put together. Something about this doesn't look quite right. I've tried searching other pictures on the forum but I'm not seeing this gap on other people's MAF sensors. Maybe they are using a different brand, I'm not sure, or maybe I'm just missing something. I feel like the coupler should slide all the way up, but I'm not sure how it would.
Here's the finished product. Fortunately, I didn't have to glue any pieces together. Is this gap normal or OK?
Thanks,
Old Dec 2, 2018 | 06:05 PM
ls1nova71's Avatar
You're using a generic coupler, you can't expect it to fit like factory because it's meant to fit many different applications. If it were me I would trim a small notch out of the coupler. Its rubber, a razor blade should be all it takes.
Old Dec 2, 2018 | 06:23 PM
Vetteman61's Avatar
OK, thanks. I was concerned that this may not seal properly or could somehow have a tendency to come loose.
Old Dec 2, 2018 | 06:30 PM
That's gonna be a clean-looking air intake once you "detail" it as above. It'll have a nice "factory" look to it which I like.
Old Dec 2, 2018 | 06:51 PM
Vetteman61's Avatar
Thanks. I really wanted to hide the MAF sensor under the box next to the air filter. I really prefer the look of just a tube. I read a lot of threads on the forum about MAFs, and though there were lots of opinions, the consensus I gathered was that it is best to be several inches away from the throttle body, not right up against the air filter, and have several inches of straight pipe in front of it. These are not absolute requirements, but that the best operation is achieved under these areas. Since this build is most about practicality I decided to follow function over form. I mounted the MAF a little further up the tube (toward the throttle body) than I wanted to. If I could have moved it down some more I could have turned the MAF over and hid the box and connector, but as it sits now I think if I turn the connector down I may run the risk of the wires getting caught up in the belt drive by accident. I was glad I didn't end up having to glue any pieces together. I don't think I would have been happy with the results I would have gotten if I had attempted that.
Old Dec 2, 2018 | 07:32 PM
Function over form is the WAY......
Old Dec 2, 2018 | 08:02 PM
Vetteman61's Avatar
What is that little round tab on top of the MAF for?
Old Dec 2, 2018 | 08:17 PM
Michael Yount's Avatar
I don’t know for sure - but often little tabs like that accept a plastic fitting that holds a wire loom clamp or piece of tubing in place.
Old Dec 2, 2018 | 09:09 PM
Unless you have any wiring going that way to tie off, you COULD trim it off for the cleaner look you are attempting.
Old Dec 2, 2018 | 09:15 PM
onebadbowtie86's Avatar
I trimmed/shaved off that little square tab so my coulplers would slide all the way onto the MAF sensor.
Old Dec 3, 2018 | 05:51 PM
LS1 TJ's Avatar
Same for me. Break out the grinder and get rid of the tab. I've done it on a number of swaps with no ill affects.
Old Dec 3, 2018 | 07:35 PM
Vetteman61's Avatar
Gotcha. Perhaps a time to get the dremmel out. If the little round part might be to hold wires, what is the purpose of that tab?
Old Dec 3, 2018 | 07:41 PM
Hard to say. I think you should get this thing running and totally functional, THEN start trimming off unneeded tabs, loops, etc.
Old Dec 4, 2018 | 05:26 PM
350SS's Avatar
so the maf is clocked correctly when assembled with the intake tube. sensor housing up i would guess so that moisture or stuff doesn't accumulate in it.
Old Dec 4, 2018 | 05:32 PM
Project GatTagO's Avatar
^This...
Andrew
Old Dec 4, 2018 | 08:21 PM
Vetteman61's Avatar
So do you think I should clock it up as well? I was hoping to put it down to hide the ugly parts, but if it might cause trouble I'll turn it up.
Old Dec 4, 2018 | 08:37 PM
Yes, it should be clocked "up." Look at pictures of any new car engine bay. Some are off to the side a little, but they are mostly up. You can probably get away with being 90 degrees to the side, but no downward angle. Kind of the same rule as mounting O2 sensors in the exhaust.
Andrew
Old Dec 4, 2018 | 09:51 PM
Vetteman61's Avatar
Are you just sayin that cause you know it's going to drive my OCD crazy. hahaha
Old Dec 4, 2018 | 09:58 PM
Awww c'mon! You think we do crap like that??? Well if it's good for a giggle or two, then yeah... LOL
Old Dec 4, 2018 | 10:00 PM
