E-rod LS3 and in tank fuel pump recommendation
My understanding is the E-Rod needs to run returnless. I don’t believe the 11540 is recommended for returnless setups however.
Can I retrofit one of the stock 2010 Camaro SS pumps to the Spectra 203FI tank? What pump do you recommend that works best with the E-Rod?
thanks!
this is an option...you may be able to keep existing tank.
