Engine Squealing
Old Mar 25, 2019 | 07:53 PM
mudbog42's Avatar
Default Engine Squealing
Hello all,
I just got my conversion on the road and it has now begun to make a loud squealing noise. I thought for sure it had to be the belt because it sounds just like a belt squeal, but its not. I pulled the belt off and it still makes the noise. It almost sounds like it is coming from the engine unfortunately...the motor is a 2005 5.3l. Has anybody dealt or know what could be causing this noise? Any help would be greatly appreciated. Thanks!
Old Mar 25, 2019 | 08:12 PM
Did you do anything to the engine before installing it? Coming from the front or rear of the engine?
Old Mar 25, 2019 | 08:14 PM
mudbog42's Avatar
The only thing I did to it was swap out the truck manifold for a LS1 intake, but no internal work. It sounds more like the rear of the engine.
Old Mar 25, 2019 | 08:25 PM
Could it be a vacuum leak? Does it fade on opening the throttle or change its sound?
Old Mar 25, 2019 | 08:43 PM
mudbog42's Avatar
The sound does change with engine speed. Here is a short video of the noise. The exhaust is kind of loud so you'll have to listen for it.
https://streamable.com/n5bbr
Old Mar 25, 2019 | 08:55 PM
Vacuum leak. It goes away as soon as you hit the throttle, and comes back once vacuum builds again. It could be a manifold vacuum fitting with the hose off, or one of the gasket O-rings is leaking. Check your whole manifold install.
Old Mar 25, 2019 | 09:00 PM
mudbog42's Avatar
Thank you! Looks like I have a project for tomorrow hunting down this vacuum leak.
Old Mar 26, 2019 | 10:18 AM
Project GatTagO's Avatar
^^^I agree.
Andrew
Old Mar 26, 2019 | 04:23 PM
mudbog42's Avatar
Just wanted to close the loop on this in case anyone else ends up with the same issue. Turns out I had the PCV system plumbed incorrectly when I went from the truck intake to the car intake. All seems good now. Thank you so much all the help!
