2 second start not vats
Old May 14, 2019 | 12:25 AM
tigersimone's Avatar
Default 2 second start not vats
Hi Everybody
Is ther any othher things to adjust without the vats when the engien only fires up
for 2-3 seconds.
Its a 2012 ls3 out of a Camaro used hp tuners to remove vats and clutch errors
the live vcm sas in fuel lo not ready.
Old May 23, 2019 | 10:56 PM
rockusaf's Avatar
I had a similar problem with my build, also happened to be a 2012 Camaro LS3, had to put the intake tube on to get it to run, something about the air over the MAF the computer didn't like and killed it after a few seconds. I sent the ECU to the tuner to try few things and make sure the VATS was turned off but once I simply put the 4" intake tube on I used to connect to the filter it started and ran fine. Can't remember where I read to try it but it doesn't cost anything to give it a try. Good luck.
Rock
Old May 24, 2019 | 05:38 AM
underpowered's Avatar
X2 on making sure it has a MAF on it. same issue when i did first fire up on my engine. Put intake tube and MAF on it, fired up immediately
Old May 24, 2019 | 04:07 PM
No Did try this but no luck i just dont gert rid of vats for som reason
Old May 25, 2019 | 01:49 PM
kpeters59's Avatar
Low Oil Pressure kill switch?
-KP
Old May 25, 2019 | 03:27 PM
Project GatTagO's Avatar
As far as I know, GM does not use any sort of low oil pressure safeties. They don't care if you run the engine dry and blow up your junk.
Andrew
Old May 27, 2019 | 12:26 AM
kpeters59's Avatar
Well, my '96 TBI had one.
If Oil Pressure goes away, the Fuel Pump turns off.
-KP
Old May 27, 2019 | 12:44 AM
kpeters59's Avatar
As reported in this thread:
https://ls1tech.com/forums/conversio...-second-2.html
-KP
Old May 29, 2019 | 01:19 AM
Default Only 2 second start
-KP
I have tried everything tried putting vats back in and there was no start at all then took away vats again and got the 2 second start back
Old May 29, 2019 | 09:10 AM
kpeters59's Avatar
Well, I'm just a leach off this Forum, but how is an Oil Pressure Signal getting to the ECM?
-KP
