Dumb Electrical Question
Old May 28, 2019 | 11:43 AM
TipsyMcStagger's Avatar
Default Dumb Electrical Question
The GTO/LS2 (and probably most other LSx engines) has the left and right injector/coil banks each fused on a separate 15A circuit.
If both of these circuits are wired through a common relay, does that relay need a capacity of 30A (or greater)?
Or would a 20A relay be sufficient?
Old May 28, 2019 | 11:46 AM
Project GatTagO's Avatar
You're taking two loads and combining into one. Now that one circuit has to handle twice the load, so the wiring and the relay have to handle the double load. So 30...
Andrew
Old May 28, 2019 | 11:47 AM
pdxmotorhead's Avatar
Given the price difference I'd use a 30A relay, the 20's are typically much lower quality for who knows what reason, at least on my cars they die more often (Not vendor specific either. )
Old May 28, 2019 | 11:57 AM
Thanks. That's what I thought. Just needed confirmation
It's not the cost, it's the availability. I was considering running two 15A fused circuits in the 4 circuit (8 position) Eaton Bussmann distribution bus on this page.
But it appears 20A ultra-micro relays are the largest available. If there are 30A ultra-micro relays, I'm not sure where to find them.
Old May 28, 2019 | 01:10 PM
LSswap's Avatar
Let's assume we're talking about high impedance injectors.
A typical high impedance injectors draw about an amp. Even if all eight are on at the same time, current draw would be about 8A. A 20 amp relay should be fine.
The fuse is designed to protect the wiring against a short circuit, so the max size of the fuse is designed based on the wire gauge rather than the load. You're doubling the number of injectors, but you're not increasing the size of the wiring feeding any injector. I don't think a 30A fuse is a good idea. A single 20 amp fuse should be fine.
Old May 28, 2019 | 01:25 PM
I wasn't planning a single 30A fuse. I was was planning two separate 15A fused circuits (one for the left injector/coil bank, one for the right injector coil bank), both run through a common relay.
You're suggesting combining both left and right injector/coil banks into a single 20A fused circuit?
Old May 29, 2019 | 09:36 AM
LSswap's Avatar
Sorry, I must have been tired when I read what your plans are. I didn't notice that you're also running the coil banks on the same circuit as the injectors, so my previous comment is not applicable.
I don't have any data on coil current requirements, but I would guess they have a larger current draw than high impedance injectors.
Old May 29, 2019 | 10:58 AM
Yes, that's the way they are wired from the factory; Coil/Injector Bank 1 Fused 15A & Coil/Injector Bank 2 Fused 15A. I'm just going to replicate this.
There doesn't seem to be a 30A ultra-micro relay available to fit in the Bussmann block, so I'll use a different fuse block and run both 15A circuits through a 30A relay.
Old May 29, 2019 | 12:13 PM
Michael Yount's Avatar
220, 221 - whatever it takes.
Old May 29, 2019 | 07:15 PM
EFIHARNESS's Avatar
You can put all injectors and all coils on one micro relay in the bussman box. They are rated @35 amp. Protect the circuit with a 15 amp fuse. We have done thousands of these over the years with this setup. On the ls system the total current draw on coils and injectors at full throttle is approx 12 amps. Yes I know each injector pulls approx 1 amp however they are not all on at the same time. Steve
Old May 29, 2019 | 08:24 PM
Just so I'm sure I understand your intent, you're saying to fuse all 8 injectors and coils (Banks 1 & 2 combined) on a single 15A circuit?
If so, that surely simplifies things!
Old May 29, 2019 | 09:47 PM
EFIHARNESS's Avatar
Yes. Steve
Old May 29, 2019 | 09:55 PM
Yes. Steve
Great. Thanks for the information!
