My 64 build
1. I used Tanks Inc, tank and their in tank pump, easy install, only draw back is its noisy. There are a few threads here detailing a pump swap that is much quieter and I will probably be looking into that.
2. Its pretty much bone stock truck motor, for me it was easy keeping it as close to stock as possible. I did do the harness myself using Lt1swap web site. Motor was on the engine stand for nearly 6 years while I was doing body work, once ECM was flashed it started right up with no check engine lights. FYI a stock hood wont fit with the truck accessories/alt. intake. I had two hood and both were junk, reason for the cowl hood.
3.U joints and double d shaft came from Amazon
And whats the next project? I can't figure it out in the one pic. At first it looked like an early 30s Mopar, but the A pillar looks more GM....
Did a local show this past weekend along route 66, just 160 vehicles but several nice rides and a couple accolades, got first in the 1960 to 74 custom class and best interior over all.
