What dont i need on a LS1
Placing in a 1962 SS impala convertible
I have been researching but am still basically a newbie when it comes to LS swaps and everything that goes along with it.
I have a few questions if anyone could help me out a bit, it would be appreciated.
What hoses etc can i rip off that i wont need later?
Also i have seen some folks that flash the PCM and rework the wiring.
i want to put in a dakota digital dash as well.
i have a very long way to go.
Here is a few pics.
Do a little homework on how engines work and what came which years.
You would be able to tell if your engine has either one. It's all external.
I have done research but it is just alot to take in so i joined a LS forum hoping there was some folks that would be willing to help a newbie with a few dumb questions and hoped there was some folks that probably new a little bit about ls engines. I have used the search function and google.
I will keep researching to the point where i wont need to ask any questoins. Appreciate the help.
You might want to install a set of decent high flow cats, given that you have a convertible. My swap is a 1971 GMC Jimmy, which is also a full convertible. I have a 6.0 (LQ4) with a 223/231 cam, and no cats. I do get some exhaust smell at startup and idling at times. Enough that I feel that it clings to my shift, if I drive to work in cool, damp mornings. (I'm overly conscious of smells, admittedly). The rest of the time, it's quite good, but my fueling is dialed in pretty well at this point. Something to think about. A stock cam might be efficient enough to not have any issues at idle.
Also, since you are at this early phase, and the engine is out, think about your goals. Its very easy now to make mods like a cam swap, a torque converter, etc. A small cam, and a good torque converter add a lot of fun factor with more or less no downside, other than $$$
Again, just a good time to think about things, before you put the car together and spend money.
I would keep all PCV and Evap related
Research the evap system because different vehicles use a different technique.
I do not consider these emissions devices, although many do. For me the PCV is not emissions related because it:
1. improves idle/cruise cylinder ring sealing (which improves mileage and engine cleanliness)
2. scavenges combustion gas byproducts which keeps the engine oil cleaner (which improves engine cleanliness)
3. helps maintain oil seal quality/prevents oil leaks (keeps pressure off the oil seals of the engine which improves cleanliness)
So the PCV is more of a cleanliness/ health aspect with a bit of efficiency mixed in. Hardly what I would consider emissions device, as I am barely reducing any emissions by using it. Without pcv the combustion gasses simply diffuse into the engine oil the excess pressure forces its way through oil seals over time creating leaks, the rest blowing out of the engine forcefully instead of drawn out.
Next the EVAP system is implemented to control fuel smell, conserve fuel vapor (molecules of fuel in the air). To me this system is all about comfort and efficiency, keeping the fuel locked away where it can wait safely to be consumed by the engine later. It keeps the fuel tank happy by allowing pressure to escape or enter as needed and it keeps the fuel from going stale by sealing it up from the atmosphere.
Not a huge problem on gasoline but when you start getting alot of Ethanol content in the fuel, the tank needs to be very air tight. And that is difficult to do if you have removed the EVAP portions of fuel system, since now where will fuel vapors go? any external vent/exit which presents to atmosphere runs a risk of drawing water vapor.
hope you enjoyed
There's little reason not to keep a PCV system, unless this is a show car and you're going for "hey, look, we've shaved everything".
it means I've put a hole and re-invented baffle somewhere else
I would never permanently disable pcv even in a delete, merely relocate
Air injection can be removed - make it much easier to find headers/manifolds that fit. If you have an ls6 (2002) shouldn't have an egr valve. Keep the pcv, as mentioned it's a good thing. Fuel-evap you'd want to read up on and see what it's gonna take put it together and mount it up in your car. Not required to make it run, but it's not something that'll leave you stranded down the road either. But may help some w/ smell - as your garage/shop wont smell like a gas station.
Cats would be the biggest help, and you can find high-flowing cats that will not hinder performance more than an hp or 2. It will help the exhaust smell cleaner once their up to temp.
