ECM/BCM communication
Old Aug 22, 2019 | 04:09 PM
LS BRAVADA's Avatar
Default ECM/BCM communication
My engine/trans swap is almost complete.
L76/6L80 from Pontiac G8 GT into 2008 Cadillac CTS 3.6L
after my tuner gets VATS removed will the ECM communicate with the BCM.
im really wanting the A/C, remote start, TUTD, cruise control and other things to work.
The high speed LAN communication wires have all been terminated into the vehicle.
thanks
Old Aug 23, 2019 | 08:00 PM
LS BRAVADA's Avatar
I got the BCM from the doner car today. I guess we will find out.
Old Aug 23, 2019 | 10:01 PM
chuckd71's Avatar
Curious to see what happens
Old Aug 25, 2019 | 05:03 PM
rpturbo's Avatar
I would love to see/hear more of what it took/you did to make this swap happen. Lots of people have said that is a very difficult swap.
Old Aug 27, 2019 | 09:45 AM
5.3Caprice's Avatar
You are doing the exact swap that I would love to do in the future. Would love to see some pics and more information about it.
Old Aug 31, 2019 | 06:11 AM
LS BRAVADA's Avatar
I swapped in the G8 GT BCM
it did not work and I had other alarms as well (locked radio, ect).
tuner scheduled to remove security
Old Sep 2, 2019 | 06:34 PM
LS BRAVADA's Avatar
Did a 30 minute security relearn and the engine fires for two seconds at a time.
now just need my tuner to get out here and do his magic.
Old Sep 2, 2019 | 08:23 PM
VATS is still in use.
Old Sep 2, 2019 | 08:30 PM
LS BRAVADA's Avatar
Yes, that's why I need my tuner to remove it
Old Sep 2, 2019 | 08:56 PM
chuckd71's Avatar
Hope it works. If I can get a similar combo into a CTS wagon I know what my next car purchase will be.
Old Sep 12, 2019 | 11:38 AM
350SS's Avatar
sorry to bug you but i posted in your other thread and came over here to look and this was the last update I saw
any progress on getting the bcm to work with the other modules (radio, antitheft, etc)
i assume disabling vats takes care of the antitheft but obiously theres alot of other modules on the can bus that you probably want working.
i've worked on some similar stuff and it seems hit or miss though i've heard some say that the vin's in the ecm and bcm need to match. i'm sure its deeper than that but just looking to learn some new info if you don't mind sharing
Old Sep 12, 2019 | 04:27 PM
LS BRAVADA's Avatar
When I swapped in the G8 BCM I had locked radio along with some other goofy stuff going on so I reinstalled the stock CTS
BCM. I did the 30 minute key relearn process (took two tries) and the key started the engine but only ran for two seconds at
a time because of VATS in the donor ECM. I had my tuner remove VATS with HPtuners. The engine starts, runs and all the fans, A/C tack, gauges and TUTD work. The ECM/TCM communicate with ABS, headlight module, BCM and any other module it needs to through the high speed LAN communication wires. Everything seems to be working correctly as of now
except for my remote start for some reason. The car is still on jack stands and ran it through all six speeds in the sport mode
(TUTD) although I get a stability warning because only the rear wheels are turning.
Old Sep 12, 2019 | 05:50 PM
350SS's Avatar
thats really cool that all that stuff works with the swap. i wonder if the vats system has to be in place for the remote start to work?
not sure how important it is to you to get it to work but if you haven't already, maybe have your guy change the ecm vin to match the bcm vin (i'm thinking its the one that matches the car itself) and then somewhere in hptuners there's a function to "relink vats" or something like that which basically should do what you did with the 30 min relearn procedure.
Old Sep 12, 2019 | 07:05 PM
LS BRAVADA's Avatar
If remote start is all that dosent work I would be ok with that. The only time I use remote start on any of my other vehicles is to warm it up in the winter. i will have him check with hp tuners when I get this thing on the road. Thanks
Old May 17, 2020 | 10:31 AM
Toddah's Avatar
Default So what are the minimum connections to get the BCM talking?
I have a 08 G8GT 6.0 and 6L80E. ECM, TCM and TU/TD shifter and pedal in my 66 Malibu runniNg and driving.
i woul like to add the BCM for TU/TD initially but Cruise control, nutural safety switch, backup lights and such down the road.
i have read alot and my thinking is if I can provide power (switched and constant) and GMLan + and - for both high and low speed bus. I think that will provide communications to ECU and TCU.
then its a matter of wiring in the connections to the shifter on the x1 thru x5 plugs that will provide TU/TD communications to the TCU.
Also can anyone tell me if there is a harness that ties to the BCM as a stand alone thing or are there just a bunch of terminals in the dash harness?
i will need the connectors to move forward.
