4l80e segment swap
Old Aug 27, 2019 | 02:09 PM
sowbelle's Avatar
Default 4l80e segment swap
Can a 4l80e be segment swapped to an 2007 e38 ecm from a silverado?
I have a 07 6.0 that had a 6l90 with it. The 6l is burned up and i dont want to cut tunnel up in car.
All this going into 74 Olds 442
Thanks for any help
Old Aug 27, 2019 | 07:29 PM
brandon6.0's Avatar
It might be.
I have a e38 tht originally had a 4l70e.
I run a 80e behind it with a few tricks to the tuning and a 80e/60e relay conversion harness.
Old Aug 28, 2019 | 09:22 AM
sowbelle's Avatar
Brandon
Did you use the t42 TCM?
Where is the relay harness availabe from?
Thanks
Old Aug 28, 2019 | 10:56 AM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You have to use a T42 TCM.
There is no reason to use a Relay harness if you have a 4L80e harness. If you do not, you are better off using an adapter harness and the proper OS for a 4L80e. Then it all works as GM engineered.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Aug 28, 2019 | 11:22 AM
sowbelle's Avatar
I have the 4l80 harness.
It sounds like i need to look into an adapter harness fm t42 to the 4l80?
Is there info out there on pinouts and diagrams?
Thanks for all the help
Old Aug 28, 2019 | 11:53 AM
LS1Tech Sponsor
If you have the correct engine harness it will have the T42 TCM connector. At that point, you just need a T42 TCM with the appropriate calibration.
__________________
1-888-467-4491
Old Aug 28, 2019 | 03:04 PM
sowbelle's Avatar
Can a t42 be programmed with HPTuners?
Should I say calibrated?
Old Aug 28, 2019 | 10:26 PM
brandon6.0's Avatar
Yes it can be tuned to work. Its a 07 tbss tcm so im pretty sure its a t42
Old Aug 28, 2019 | 10:32 PM
brandon6.0's Avatar
Got my harness from Pcm of NC
