Picking LS swap option for 1974 C10
I just picked up a Truck and need to pull this old tired 350 out of it. I have an LS6 in my 66 Nova and while that car hauls *** this truck is like 1500lbs more. Im interested in getting some input on swap options. I would love to do a turbo 5.3 but I really dont have 10k to put into it. This will be a used as a DD and needs to be an automatic. I have a budget of $4000 that I can spend on the engine. I was looking at an LQ9 with cam call it a day but wanted to know if there is something else Im overlooking.
Joe
stock its got enough power to be fun.. If your a skillful hunter you can score a complete one for about 4K with transmission..
Unfortunately they often go higher..
Love that vintage of GM SWB truck..
I would guess a reasonably hopped up 6.0 would make you into a 12 second truck. I suppose you can youtube all the Roadkill Muscle truck videos to see what that one did, cammed LS6, not anything special, with a TH400 and 5.13 gears.
A nice place to start would be an LY6/4L80e combo from a Van. Toss in a cam and headers and it'd be a quick combo.
If you are wanting an 11 second or faster type ride, then, yeah, I'd find a 4.8 or 5.3, 4L80e, and turbo. But may be more of a challenge with the budget. Depends on if you want to go with the sloppy style or not. OR run a setup like mine, NA, and then graduate to a turbo later. With my compression ratio, I could slap one on easily if I wanted to (and destroy my 4L65...).
In all cases, in a classic like yours, I'd look strongly at the Holley Terminator X Maxx to control both your engine and trans. Great value, and can handle a basic turbo setup.
Joe
Joe
My 71 is a handful at anything other than a straight line. Its primary use is still hauling stuff so it needs to be utilitarian d2d... Yeah I can beat up some high end cars in a straight line, but I would not consider the C10 safe doing it by any means.
Everyone wants 500+ street which makes no sense to me as a real daily. IMO the ~400 mark is easy and reliable for a daily w/o going pure ape roasting meats at every stoplight or banging 2nd and getting loose.
You have a great looking truck, just keep it real for a daily.
Even in a straight line, it's not the "going" that scares me, but then I have to stop it. I've got all new hardware everywhere in my brake system, larger drums from the truck HD brake option, and a 1 ton master/booster, but with 33s, its not great.
Make sure your budget is considering everything, and not just the engine/transmission itself. Many people don't budget for a good converter, good diff, and proper axle gears. That can make a big difference on your overall experience with an automatic. Most people like at least a basic TransGo HD kit in a 4L80e, and ditching the massive stock converter will help. Matching Cam, Converter, and Gears should eliminate any sluggish feeling often associated with automatics, even with a cammed 5.3 in that truck.
