I seriously like to know what everything weighs. The motor sits way back against the firewall in this swap, I can squeeze a finger in between the right head and firewall, later that proved to be a slight mistake as it was effing difficult to do a thing back there, upper trans bolts, ground wires, harness routing etc..
Cold air intake coming from the area between fender liner R. Headlight, 102mm (4”) with 2 bends, a 75* and a 90*
Exhaust system is 3” v- band connected with x-pipe, 18” Bassani flow throughs , FlowMaster 3” tailpipes, yep, there’s 2 small cats in there as well, helps keep the noise down and avoid those $1k fines they’re handing out here.
Eaton TruTrac clutchless 31 spline and Ford Motorsport axles replace the stock stuff. 3.55 gears, 3” hardened studs, axle tubes welded in 3 places per side
I’m putting together a similar LS1 for my Vega: Same Wiseco Pro Tru pistons as you with a .005 over LS1 block and gen 4 rods Did you ever make it to the track or on a dyno?
I saw where you were unhappy about the bob weight. I understand your concern as the pistons are hefty, but actually your bob weight was really close to stock LS1. I’m hoping it doesn’t take much to balance mine. Thanks Dan
