Thinking About Ditching EFI
Here's my thought process. I have a stock LQ9 that runs fine, but I want to start modding the engine and transmission for drag racing. To do that I will need to spend $650 on HP tuners, but I don't even know how to use the software. From what I understand, it's very complex. I could pay someone to tune it but I plan on modding it incrementally.
Here's why I think I want to go back to a carb:
1) I'm bored with EFI
2) I know how to tune a carb
3) I don't want to spend $650 on software I don't even know how to use.
4) don't need a tuner
5) EFI is ugly.
6) Electronics are a PITA and I would rather not deal with them when a problem arises.
I'm thinking I could sell my PCM and new PSI harness to cover the cost of the carb swap.
Am I crazy or is this logical?
But you know what you want. No reason to even ask us.
On a daily driver I would go EFI, If it's weekend cruiser/street strip/ strip only then a carb can be made to work well.
Never really had an issue with one. Except with this shitty ethanol blend gas. My 396 Suburban sat for the better part of the year and doesn't want to idle, getting some pops here and there. But thats my fault for letting it sit without starting for so long.
I say goferit. Or a simple carb style efi. I've got an Fitch kit sitting on a shelf for 2 years now. Just not in a rush to run fuel lines, fuel pump, 02 sensor etc......
The challenge with EFI has always been understanding the software and the ECU design/concepts, what everything does. Systems like the new Terminator X bring in a much easier to use interface with a very good price point. I hated messing with HP tuners, and find the Holley setup much better for me. I would never go back to a factory ECU for my setups (swaps into older cars that don't need any other info from the ECU).
If you have an LS motor with typical OEM parts, it might be more expensive to go with a carb vs a base Terminator X setup. Intake, Carb, Spark box, carb tuning parts, etc. Cheaper if you already have carb parts.
IMO, tuning is the same, you have to figure out the same things whether its EFI or Carb. You need to tune Idle, cruise, WOT, pedal transitions, spark curves, etc. In the end, you have to understand what the car needs, and how to set it up.
With a carb, you test it, and change some parts (so you need a stock of assorted parts). And you need to figure out how you are getting data. Factoring in a wideband is more money. With a good EFI system, you already have the wideband and you also get datalogging that makes it much easier to tune. I would think this would be a benefit for drag racing also.
5) EFI is ugly.
You will still have electronics controlling timing if you use a msd box.
That Sedan Delivery up there looks clean, something like that I would run the EFI Throttle Body systems that are out now, they look nice and would look clean.
The majority of people I have ran into who want to retain a carb because their screw driver is mightier than my laptop, are the ones who are currently in a middle of a domestic dispute in front of their trailer, PBR cans all over the ground, a 3rd gen Camaro on blocks in the front yard, wearing a wife beater screaming at their spouse who is some form of sibling in the family tree.
There is pretty good community support for HPTuners and EFILive, It's a more extensive (and expensive) conversion, but the Holley stuff is another EFI option that is pretty easy to use.
As far as LS Dizzy kits... troll level master..
EFI is great but there is a little difference in power if properly setup and tuned, Not everyone wants or needs EFI.
If the OP can tune his car with a carb and make it perform the way he wants and saves some money that can be used elsewhere then I don't see why he shouldn't do just that, It sure they hell doesn't make him trailer trash.
PS; The owner of the Sedan Delivery is running a carb because EFI isn't allowed in his trailer park. Besides he can't afford it plus buy the PBR and still have bail money when he beats his sister-wife and kids. How do you come up with stupid **** like that anyway? Must have been dropped on your head by your nanny when you were a baby or nearly choked to death on your ego.
EDIT: And the engine going into my soon to be street legal sprint car.
This is a battle of wit, which you clearly are unarmed for.
You already seem to be offended at the light banter.. I haven't even started yet. You should learn to swap some thicker skin.
I'd hate to see the straight edge non-vulgar no fun garage you have.. are people allowed to drink stuff besides water?
