LM7 into 71 Nova issues
The only issue is the front of the pan is resting on the cross member before the mounts get seated where I can put the motor mount bolt through them. I am using the original frame mounts that were in the Nova. And I am using Jeg's LS engine mount kit with rubber mounts.
https://www.jegs.com/i/JEGS+Performa...BoCkjgQAvD_BwE
At first I was thinking, ok as expected i am having oil pan clearance issues with the truck pan, but this is the front part of the pan, not the rear sump. So I then started looking at the mounts.
Any help is appreciated. Thank you!
Use their mounts, their pan, their crossmember, and if desired their headers/exhaust.
Yes, it costs more INITIALLY, but it WILL all fit and work together instead of haphazardly mixing/matching parts and hoping for the best.
Rick
Rick
BTW, if your name above is what you have done, my hat's off to you! Thank you!
V8 Nova's had two frame bracket choices. Small block and Big block.
The big block stands (which I used) mount the engine about 1/2 to 3/4" towards the pass side and mount the engine lower than the small block stands.
So if you have BB stands, the truck pan will hit the crossmember.
No matter, the rear sump will practically drag the ground.
Ditto on the Holley recommendation. Very nice parts that fit. The Holley pans will also clear the crossmember.
I just installed a 7qt Moroso pan, and had to notch the crossmember to clear.
Good luck with the project!
Ron
Keep in mind that the 68-74 Nova and 67-69 Camaro had the same subframes and are rear steer. The truck pan fits with a slight crossmember notch but hangs down a couple inches, The F-Body pan fits and doesn't hang down but interfers with the drag link without clearancing either the pan or the drag link.
The Speed Engineering headers fit perfectly on my Son In-laws 73 Nova with a 4l80e and they are very cheap considering they are polished stainless and actually built well.
The pictures on the instructions for the exhaust system are mine, which is pretty cool to see.
All in all, after 6 years of having the car running, everything is still in great condition. I would just buy their engine mounts, oil pan, trans mount and headers. Up to you if you still want the rest.
