Alternatives to Griffin radiators?
I used a Griffin radiator for my LS Swap. My first one started leaking between the core and tank. Summit, who has always been great with customer service, replaced the radiator. Now, my 2nd radiator is leaking in the same way. Reading online has shown this to be a common issues with Griffin radiators.
What is a quality alternative to Griffin radiators?
Thank you,
Brandon
If your hoses can possibly work for a stocker, that's the easiest to exchange at your nearest auto parts w/ lifetime warranty.
I've put over 100,000 miles on the aluminum core, plastic tank radiators and they cool just fine in 120 degrees.
Attachment 713842
Attachment 712742
The original radiator mount was a large, two piece plastic shroud that encapsulated the radiator as well as had the huge shroud built in, so I can't use the original mounting setup.
As far as quality control with the Griffin radiators. This is something that our quality control team is currently working on with Griffin. Being a large retailer we get numerous amounts of good and bad feedback that we can relay to the manufactures and vendors that we carry.
OP, the community has recommended some great alternative radiators for you. You're in good hands.
