Harness conversion question
Old Mar 8, 2020 | 02:52 PM
HappySalesman's Avatar
Default Harness conversion question
I'm going through the process of converting my harness from an 08 tbss for a swap into a dakota. I'm keeping the 4l70e and the associated wiring.
One wire I ran into is on the plug for the park/neutral switch. the last pin is labeled "crank voltage" and is circuit 639. Goes back to the fuse box. Anyone know what this wire is for? I cant find it in any diagram anywhere. Thanks!
Old Mar 9, 2020 | 06:08 AM
Murray's Avatar
Default .
Does this help?
https://ls1tech.com/forums/conversio...rse-light.html
Old Mar 12, 2020 | 11:44 PM
It does! Thank you, that's exactly what I needed.
