2 Wire Alternator Question
Old Jun 29, 2020 | 09:13 PM
Josh Beverly's Avatar
Default 2 Wire Alternator Question
I have the PCM from a 2005 Suburban L59. The connector is the 2-wire setup. My alternator is also a 2-wire unit so no problem there.
Do I need to relocate the brown and gray wires to pins 15 and 74 on the green connector like it says on the LT1swap website? Or do I need to put them back to where they came from (what pins)?
Also, the gray wire coming from the 2-pin connector has a splice and two gray wires coming off of it. Do I need to terminate the second grey wire somewhere else, or can I cut one off and run the other to pin 74?
http://lt1swap.com/2004vortec_pcm.htm
Old Jun 30, 2020 | 10:50 AM
SwapStang's Avatar
I guess you'd have to figure out if you have this "generator battery control module" that he's referring to. That would be the only reason to swap those pins. I'd have to guess that's not in the PCM or the alternator and probably unique to the BCM's on some GM's. That's just my guess though. You can always swap those pins later too that isn't a big deal.
Old Jun 30, 2020 | 11:24 AM
I do not have the GBCM. I did not pull the negative battery cable from the truck and the unit is built in to this cable.
Old Jun 30, 2020 | 11:53 AM
SwapStang's Avatar
I guess the only question is do you WANT to run one? It is mounted inline on the negative terminal but there seems to be a bit more to retaining it than that. 8 or 10 wires need to be ran. Here's a pretty good write up of keeping it. https://ls1tech.com/forums/conversio...dule-gbcm.html
Old Jun 30, 2020 | 11:54 AM
I don't want to keep it if I can run the two wire system to the PCM without cooking the battery.
Old Jun 30, 2020 | 11:58 AM
SwapStang's Avatar
I guess the purpose of it is to maintain a more steady charge rate and prolong the life of the alternator. I personally wouldn't run it, seems like kind of a waste of time unless you have so extremely demanding charging system. I wouldn't worry about your battery at all.... and for what it's worth i have a 99-02 harness and that ran 1 wire. 3 years and all good charges like a champ.
Old Jun 30, 2020 | 12:03 PM
Ok. I understand a lot of people trick the system in to providing a constant 13.8V. I do not know if that is especially high or low. I just don't want to run the battery too hot and/or boil off all the electrolyte.
Old Jun 30, 2020 | 01:06 PM
SwapStang's Avatar
I don't know that trick mine just runs the same way it was meant to in 2000 haha. Puts out a constant 14.3 - 14.4 drops to 14 ish when the fan comes on. As long as it isn't putting out some ridiculous voltage I wouldn't worry about your battery.
