Ls swap A/C wiring Blue/Red truck harness
Okay so I am reworking the harness for my ls swap and everything has gone very smoothly and I am nearly done but I have not figured out how the A/C compressor wiring is done. I want the pcm to control the A/C so it will kick up the idle and the fans.
I know I have to ground pin 55 to always have a low pressure sensor signal. Then there are the two plugs that plug into the A/C compressor. Plug 1 having the wire coming from pin 17 A/C request and a wire for AC high pressure cut out switch from the fuse block. Plug 2 has an AC compressor clutch solenoid feed from the fuse block and a ground wire.
What do I do from here forward? I’ve read lots of questions about how to wire blue/greens and ls1 wiring but not many people ask about red/blue trucks. Maybe it’s really simple and I just dont understand what actually powers the compressor.
Based on this wiring diagram ripped off of lt1swap, I don’t actually mess with wire that goes from pin 17 to the compressor. I just have a switch with 12v+ to the light blue wire that was on the same plug? And as long as the compressor doesn’t see high pressure then the cutout switch will connect the 12v+ to pin 17 kicking on the fans. Is this correct?
I still don’t know what to do the the other plug on the compressor
Correct on the PCM not being needed for A/C idle control. My PCM adapts the idle speed very quickly to the change in load on the motor. I also run a relay assembly to kick on one of my two e-fans immediately once the compressor kicks on - Four Seasons part number 35879. This is required to control AC compressor head pressures because we can't wait for a fan to turn on at normal fan turn on temperatures and my system uses the standard sensors in the AC lines to prevent over and under pressure damage.
Rick
Rick
https://www.amazon.com/Four-Seasons-.../dp/B000CSYRRC
Rick
Rick
