Questions on 2 Pins Blue/Green
Old 10-23-2020, 04:26 PM
Vetteman61's Avatar
Default Questions on 2 Pins Blue/Green
On the Blue/Green ECM (2004)
Blue Pin 75: off/run/crank voltage.
Green Pin 59: Crank voltage.
What do these do? Where do they go and what are they for?
Thanks,
Brandon
Old 10-23-2020, 08:41 PM
ls1nova71's Avatar
Blue pin 75 is an ignition power to the PCM, and green pin 59 is the wire from the ignition switch if you're using a PCM controlled starter relay, most people delete it.
Old 10-26-2020, 06:59 PM
Vetteman61's Avatar
Thanks!
Quick Reply: Questions on 2 Pins Blue/Green
