C4 Corvette with LS 6.0L
So I am having an issue with my LS swap into my 1984 C4 Corvette. Actually, probably going to have many issues, it’s a terrible and long story. At the moment, the issue is that when I start the car it runs really poorly and stalls. Terrible idle. And if I give it throttle it hesitates, stumbles, and dies. I have two videos of the car running. The first is with me just starting the car, giving it zero attention other than the start.
the second video is of how it runs when I give it throttle.
I would greatly appreciate any help. I am sure you guys are probably going to want more information as well. But let’s start here, thank you.
As usual, your help is always greatly appreciated.
The rev sounds like a down cylinder. Again, change the plugs and two new GM oxy sensors. See if this helps
If it starts running better you need to check to see what the problem is.
Also are you running stock exhaust manifolds or headers. The location of the O2 sensors can affect how it runs.
If vacuum has affected it that much I would look for move vacuum leaks and no rule out you may have a leak inside the car under the dash.
I am running stock C5 short exhaust manifolds, so I figure the distance is fine for the o2 sensors. The o2 sensors are brand new with the swap.
I checked the fuel pressure and it seems to be fine, no issues.
I ran a live scan for data while it ran, checking different parameters. What I noticed was that the scan showed that the long term fuel trim on bank 1 was dumping fuel, whereas the other bank seems to be in a regular level.
I am thinking there is still some sort of vacuum leak but no idea where at. I have built a smoke machine to test the system but it keeps blowing a fuse at the moment. Lol, if it’s not one thing it’s another.
