low profile intake help for ls swap
Old Nov 19, 2020 | 06:22 PM
ss67's Avatar
Default low profile intake help for ls swap
hello i am swapping a ls into a 63 riviera i have a gen4 6.0 truck engine.i am needing help trying to figure out what the lowest intake manifold i can use due to hood clearance issues.i have been looking at the ls3 intake and fuel rails.i need it to be as low as possible and be able to use the truck dbw throttle body and fuel injectors.i see aftermarket ones on ebay for fair price they look low profile but i have never heard from anyone that has used them.or whats the best combo you ls swappers are using.any info really appreciate thank you very much have a awesome day
Old Nov 19, 2020 | 09:45 PM
If your engine has rectangular port heads, the LS3 manifold should work well.
Old Nov 20, 2020 | 12:21 PM
ss67's Avatar
ok thank you .do you know if i can mount the truck throttle body and injectors without mods.i read somewhere that the injectors from a truck will not work unless modified is that correct.thank you for your input
Old Nov 20, 2020 | 01:04 PM
Both TB's are 4-bolt, however the truck injectors are 50# and 1.73" between O-rings, where the LS3 injectors are 42# and 1.50" between O-rings.
Old Nov 20, 2020 | 05:05 PM
ss67's Avatar
thank you.so if i buy a ls3 intake i should make sure i get fuel rail and injectors.and i have been reading some more on it looks like i will need intake bolts and map sensor also from what i have read says truck map and intake bolts will not work with ls3 .thank you for your input
Old Nov 23, 2020 | 12:35 PM
1964SS's Avatar
What year 6.0 are you running? Gen 4 goes all the way back to 2005. You may have a cathedral port 6.0 not a rectangular port.
Old Nov 23, 2020 | 07:53 PM
ss67's Avatar
2008 ly6
Old Nov 23, 2020 | 07:55 PM
Originally Posted by ss67
2008 ly6
Rectangular ports....
Old Nov 24, 2020 | 08:02 AM
AwesomeAuto's Avatar
The only cathedral port Gen 4 6.0 was the LS2.
Old Dec 9, 2020 | 05:17 PM
ss67's Avatar
thanks for the help the ls3 intake sits on it very nice
Old Jan 24, 2021 | 11:58 AM
Retrorod's Avatar
I dodged the whole hood and air intake issue with a Victor JR and a Sniper T/B. It’s been on the road since the LS Victors came out for the LS1.
Old Apr 6, 2021 | 07:50 PM
Brad Pontiac's Avatar
I purchased the Victor Jr also, but I don't have it on thee street yet, nor is it tuned properly, since I'm doing the body on it. I assume you are set up for speed density, right?
Do you have issues on the street as temps and seasons vary,I'm wondering if I should do a MAF or not.....
I would value your thoughts.
Thanks
Old Apr 7, 2021 | 11:31 AM
Retrorod's Avatar
PM sent
