2008 Yukon ECM with a 2013 engine and Accelerator pedal
Does anyone know if a 2008 Yukon ECM is compatible with a 2013 Escalade engine and accelerator pedal?
The reason I'm asking is because the pedal isn't responding at all. I've checked all wires and both 5V going to the pedal are good. When ignition is turned on, the throttle body seems to initialize but no response when I press the accelerator pedal. Car idles great, and the only DTC is P2138.
Which is also why you can't trust anyone. I bought the package deal with the guy assuring me that EVERYTHING came out of the same rollover vehicle. No way of knowing.
