Fuel question - 67 Camaro LS
Another option is buying a roll of Nylon line and some fittings from Dorman. I've done it on 3 cars/trucks now with zero issues. I used the "caulk gun" method to press them in rather than heating the line in boiling water. I have 3/8" line and will do so with my LSA swapped LS3 engine and have no expectations that it will be a restriction. Much more concerned with fuel pump and/or injectors.
I like this approach as well. OE quality fittings. I use this kit a lot for fuel lines...
good call. Earls ULTRAPRO- . PTFE fittings and hose are awesome to work with. They stopped making the 6AN in the black, but still offer that size in the SS hose. Super easy the assemble, light and it bends into sharp angles without kinks.
That's what I've used. Very easy to cut. You can buy 'Vice Jaws' that you can then put in the middle of a vice, to hold the body of the fitting. I screwed mine in dry for the most part, though I later found out that some places recommend a drop of oil for the threads.
I'm running -10 feed and -8 return.
What will you be going for a fuel regulator?
when doing this, what do you do with the return line off the manifold ? And what do I do to make the engine run correctly
