Help!! LQ9 PEDAL SWAP
Old Apr 20, 2021 | 10:07 AM
Vert_69_Cutlass's Avatar
Default Help!! LQ9 PEDAL SWAP
please help me bro? I want to switch gas pedals. i have the 06 gen 3 plastic curve pedal from 06 Escalade and tac module has the metal tabs on each side.. what will work? how do i wire the pedal harness to work? Do I have to retune my ecu ?
Old Apr 21, 2021 | 12:37 PM
garys 68's Avatar
With the gen 3, you're best to use the petal harness and TAC that came with the ecu/motor. You can look on Rock Auto website for the APP sensor to see if it interchanges with another year/petal. Or you could fab your own from just the sensor.
Old Apr 21, 2021 | 12:46 PM
Yeah. The pedal is to long to use or else i would. it curves too much and hits my tunnel.. I see a lot of people ising different pedals with the gen 3 vortecs. i just would like to know what i need?
Old Apr 22, 2021 | 09:51 AM
garys 68's Avatar
I just looked at the rock auto website. Good news, for an aftermarket pedal assmbly, that APP sensor interchanges with gen 4 up to 2020. You may be able to use a generic, aftermarket gen 4 pedal/sensor. OEM GM list it only for 06, 07, but that may be pedal shape/mounting related.
Old Apr 22, 2021 | 10:10 AM
wow!!?? i tried to look it up myself. i didnt find that. but could you send me the link of the gen 4 pedal and the APP Sensor.?
Old Apr 22, 2021 | 10:19 AM
the connector is totally different. the connector i have is shorter. the gen 4 pedal connector is longer?
Old Apr 22, 2021 | 10:50 AM
1FastBrick's Avatar
With your P59 computer you are limited to the 06-07 pedal and module with the current 06 operating system.
You can re flash the PCM with an 05 operating system and use an 03-05 pedal and module. The 03-05 pedal has a metal arm and you can modify customize it for your needs.
Old Apr 22, 2021 | 12:13 PM
good knowledge. i think my best bet is going with a psiconversion.com pedal and tac harness. then ill be able to send my pcm to them to reflash. i didnt know pcm has to be reflash.
