LS into a CESSNA airplane
as far as P factor (which is yaw and banking cased by prop, mostly at high power settings and low airspeed and higher angles of attack)…. The C172 has a big rudder so it wasn’t too difficult, just took time. The problem we did foresee was what if pilot got slow on a go-around (a maneuver where pilots aborts landing at last moment and applies full power to climb). Although the engine is flat rated to less than 220HP, the engine gets there very quick and can become a hand full if the pilots applies full power rapidly and is a bit slow in airspeed (below approach speed, which decreases airflow around the planes controls surfaces and makes them less responsive). So we made some changes in the tune that reduced just how fast the power can increase from normal approach throttle settings……so even if throttle was shoved to full quickly, the engine would increase power a bit slower to allow additional time for pilot to maintain control with inputs. This was a challenges as it’s a mechanical throttle controlling the EFI (needed to eliminate potential failure of a throttle by wire setup). We spent a lot of time trimming rudder and although yaw is opposite of original engine, it’s now intuitive.
About DA question…..stock Cessna engines are norm aspirated and lose rated power as soon as leaving sea level conditions. Figure about 3% per 1000 ft DA. By flat rating the V8, there is so much more airflow capacity for combustion, what is lost in decreased air pressure, is made up for in volume, allowing it to maintain the rated thrust to higher altitudes without turbos. As far as any issues with flat rating, nothing too challenging other than break in procedures as we are using new blocks. BTW, the prop pitch and design also limits max HP just above ECM soft and hard limits.
and what sort of Ls specific preflight checks? If any?
rocker arms can be problematic if after market
sourcing quality lifters etc
do you pre qualify vendors to avoid knock off ls parts? Ie Amazon fakes.
using only OEM parts to avoid the unknown.
wanted to ask for feedback on LS3 max coolant temperatures….. on hotter summer days at high altitude airports with thin air about 9-10K ft DA, reached temps up to 230F on climb out. Using 50/50 antifreeze with 22 psi cap (actual cap release pressure is effected by lower ambient air pres so it’s about absolute pres equivalent 16 psi cap at about 10k ft) so boil over point about 265 ish. Running 160F t-stat and stock pump. Norm op temps 180-220F depending on OAT and prop load, but 220-230F rears it’s head on hot days…… what is really considered upper sustainable limit for LS3 temps??
there are 2 coolers/radiators and the cowling intakes were redesigned, as well as prop and its spinner, to increase flow. We are flying it on a regular basis out of Colorado high altitude airports so the density altitude on hot days sometimes proves challenging, we posted some updates on www.corsairv8.com
thanks for continued interest in the swap
any suggestions on best method to eliminate t stat appreciated….it seems LS pump needs something to take its place.
also, any words of wisdom regarding valve cover venting and routing of hoses.. want simple method and placing some form of clear case filter element inline to monitor just how much oil is circulating. Heard everything from just leave the cover hose ports open and no need to attach vacuum , to need a catch can.
