2004 mustang 6.0 build
Car started out as a v6 manual.
specs for swap are,
6.0 with 706 heads, stage 2 btr cam, springs, ls7 lifters, and all standard up grades, 76lb injectors.
nitrous outlet plate system starting with a 150 shot
4l60e with 3000stall (I had the trans and converter, trans is completely built)
8.8 out of a v8 car with 4.10 gears.
holley terminator x Max
Upr k member
manual steering
manual brakes
home built trans member
6 point cage
rear seat delete
no stereo
airbag delete
car will be a street strip car and to use for drive/drag events.
will post some pictures of the process soon
specs for swap are,
Upr k member
manual steering
manual brakes
6 point cage
rear seat delete
no stereo
airbag delete
2004 sonic blue mustang v6
Upr k-member
Holley dash and terminator x
Built 4l60e with 3000 stall from circle d converters
Gen 3 6.0 with gen 4 pistons and rods gapped for nitrous
I’ve heard that. I have it so I’m going to try the upr member but if it doesn’t work I’ll have to swap it out.
Im just looking at swapping the torque converter as well right now.
specs for swap are,
Upr k member
manual steering
manual brakes
6 point cage
rear seat delete
no stereo
airbag delete
specs for swap are,
Upr k member
manual steering
manual brakes
6 point cage
rear seat delete
no stereo
airbag delete
