1965 Lemans Gets Booosted
Old Aug 17, 2022 | 08:56 AM
  #161
ryeguy2006a's Avatar
Wow, you work quickly! Congrats on getting it back up and running.
Old Aug 17, 2022 | 09:42 AM
  #162
Project GatTagO's Avatar
Originally Posted by brucebanner
Oh look..
Have about 40kms(25 miles) on it now, going to change the oil tomorrow and then get some more driving in. Everything seems to be good again.. Fingers crossed.
So what did you end up doing to fix it?
Also, does the turbo have any extra support besides the up-pipe from the Holley manifold and the down-pipe?
Andrew
  #163
Agreed! AND, hear, hear!
Old Aug 17, 2022 | 10:38 AM
  #164
brucebanner's Avatar
Coming towards the end of the summer season, didn't want to lay the car up for the year yet! It was like a 12 day turn around and I certainly had help.
Yes there's a small bracket to help support the turbo, I'll see if I can get a decent picture of it today some time.
Motor was stripped down, cleaned and rebuilt. Different crank rods and pistons. New rings and bearings.
Based on the pistons that cracked, essentially everyone I spoke with guessed detonation but there's was no other signs of it anywhere. Injectors pulled flowed and retested, fuel filter pulled and clean.
My tuner / engine rebuilder took the car for its first drive and logged it on his laptop, everything checks out.
So we weren't able to find a true cause as to WHY it happened. Time will tell I guess
Old Aug 31, 2022 | 02:07 PM
  #165
Cas has been back together for almost 3 weeks. Roughly 350 miles +/- driven since. Everything's all good, no gremlins have popped up (fingers crossed)
Even went to the drag strip with it haha. I knew it was a dog out of the hole but my goodness did I ever know it at the track. Only ran twice and thought I heard a charge pipe or something pop on the first run, but it was all good.
Trapped 117mph on my second and final run. If I'm going to race or drive the car that way, a converter upgrade is definitely needed haha.
Old Jan 8, 2024 | 10:49 AM
  #166
Been away for awhile. Since then, moved to a small acreage, car was sold and took back a squarebody c10 short box(350motor / 350 trans) as partial trade. Motor is definitely towards end of life. I know of a healthy 350 with 700R4 I can get relatively cheap and make a decent driver out of. Of course my brain wants to go with a cooler swap but we'll see.
I'm trying to build a garage this spring so money would be much better suited for that!
