Assuming fuel issues. Running bad.
P1514 is a big mismatch between throttle position and MAP sensor readings. It happens when there's a huge vacuum leak, or a problem with the MAP sensor, or possibly when the throttle plate is broken or has a mechanical malfunction not caught by the sensors. It means there's a lot more air getting into the intake manifold (30% more I think is the threshold) than the PCM expects for the current throttle position.
P0106 means the MAP sensor is either disconnected, or it's reading a pressure that's way out of range for the conditions the engine is operating in. For example, if the MAP sensor is hanging on the wiring harness, connected, but not installed in the manifold, you'll get this code (don't ask me how I know that).
BTW, if it's the rubber seal on the MAP sensor (missing or degraded), those are easy to find if you know the part number (GM 16194007), but can be difficult to find by the vehicle because that part comes from the "GM Performance" catalog and isn't associated with any years or models in the normal parts catalog.
it has a very mild base tune, all the lines are installed correctly that I know of, and the MAP sensor seal isn’t terrible but it also isn’t the best. I did find the hose from the front of the intake to the passenger side valve cover was split and replaced it. I removed the intake again and it seems like it sealed correctly that time. But it’s still running rough. Maybe it needs to re-tuned? I have no clue what would cause it to just randomly start acting like this. But I’ll try to replace the seal for the MAP sensor and see what that will do.
That’s kind of what I was thinking. Because the brake booster, PCV hose, the new hose I installed, the MAP sensor, the injectors, and rails are all connected. When I get time off from work again I’ll re-check everything with a fresh set of eyes.
Okay, I’ll have to try that around the intake gaskets, all the hoses, and injector ports.
