No Accelerator at Cold
Old Feb 2, 2022 | 06:58 AM
qr409tz8's Avatar
Default No Accelerator at Cold
Hello, I couldn't find anything on this in the search, but please let me know if the answer is already out there. Or if I have this posted in the right place.
I swapped an LQ4 into an old square body, 408 build. There have been a few small things that still needed ironing out, but generally it has been going well.
I am still using the stock throttle body, pedal and computer and had the truck tuned.
Now its winter though and if the truck spends the night outside in <0F weather and I start it up, it starts and runs fine, but it throws a MIL and has no throttle. I don't mean weak throttle response, I mean none. The gas pedal is completely dead. Restarting the truck does no good. If I disconnect the batter and hard reset it though, everything is fine. MIL goes off after a bit and its like nothing ever happened. Until the next time it spends the night a below zero temps.
Any thoughts? There is a bunch of stuff that is involved in the accelerator working, Pedal, TAC, Computer, Throttle body, wiring... I don't want to just start swapping stuff aimlessly.
Old Feb 2, 2022 | 10:19 AM
Does the throttle return after the engine warms up a bit?
Old Feb 2, 2022 | 10:39 AM
qr409tz8's Avatar
No. First time it happened it took me quite a while and the engine had run all the way up to operating temp and been restarted half a dozen times before I thought to disconnect and reconnect the battery. Second time it happened, I let it warm up to maybe 150F before going to the battery solution. Before going to the battery disconnect thing I tried plugging and unplugging and wiggling all the connectors between the pedal and the TAC and the Computer and the Throttlebody to see if maybe there was just a connection that got flakey in the cold, but nothing changed.
I'll see if the codes are still in the computer and post them tonight if they are.
Old Feb 2, 2022 | 10:57 AM
02*C5's Avatar
I would invest in a code reader and have it plugged in while first start up. That would give you a better idea of what's going on. I think Walmart sells them.
Old Feb 2, 2022 | 12:06 PM
1964SS's Avatar
Cheap ELM 327 code reader off Amazon and Torque app for your phone will come in very handy.
ELM 327 OBD scanner ELM 327 OBD scanner
Old Feb 2, 2022 | 01:27 PM
qr409tz8's Avatar
Thanks guys, I have a code reader. That's why I was saying I would grab the codes when I get home tonight as long as they are still in the computer. I'll post them up if they are still there. Going from memory they were TAC related.
Old Feb 2, 2022 | 07:39 PM
qr409tz8's Avatar
Ok, pulled the codes,
P1125 - Throttle Position Sensor Intermittent
P1516 - Throttle Actuator Control Module Throttle Actuator Position Performance
P2135 - Throttle/Pedal Position Sensor/ Switch A/B Voltage Correlation
Sounds like I have all the throttle codes going on here....
Old Feb 3, 2022 | 08:59 AM
cdk4219's Avatar
If it goes int limp mode( idles very rough at 850 rpm or so and no throttle response) then more than likely the throttle body is bad. Mine did this intermittently when it was cold , but not all the time. Shutting off and letting it sit for a minute would cure it. It would do this at tip in off idle throttle as well
Old Feb 3, 2022 | 09:23 AM
88bruce's Avatar
I use a battery tender and if it is disconnected with a cold start immediately after the TAC module will sustain
damage resulting in an intermittent P2135 and/or P0120 . If the battery tender is disconnected twelve hours
before a cold start, the battery voltage drains to under 13V and there is no TAC damage on a cold start. The
TAC module is the weak link electrically.
f your battery is draining down overnight, then it's possible the TAC was damaged. The point being that battery
over or under voltage could cause the alternator to spike.
A rodent got into the engine compartment of my vehicle and chewed up the wiring between the fuse box
and the TAC module, the result was P1516, P2135 codes. The other wiring potential problem area would
be the throttle body connector, which can develop cracks in the wiring, replacement is PT3707.
When the codes are generated, are you saying it's goes into reduced engine power mode, where the
vehicle is still drivable, or is the throttle pedal totally dead? The latter case would indicate an intermittent
wiring problem.
Old Feb 3, 2022 | 10:55 AM
qr409tz8's Avatar
The throttle pedal is completely dead. Re-starts don't cure it. It takes a battery disconnect and reconnect and then it runs fine. Next time it happens I also want to pay attention to idle speed. I figure if it goes to high idle and then steps down that at least the computer still has control of the throttle body and that maybe its the pedal. Or maybe other way around if idle never changes. Its tough to debug because I need to park the truck outside in <0F weather for it to be an issue. I could also try graphing the voltage on cold start next time I suspect its cold enough out for it to happen again...
Old Feb 3, 2022 | 12:05 PM
cdk4219's Avatar
More than likely the throttle body. It will run but it runs rough and stays at 850 to 900 rpm. It would sometimes take 4 or 5 restarts to correct the issue. Mine was intermittent, but got much worse when cold, to the point of doing it at in opportune times like in traffic on the freeway.
Old Feb 14, 2022 | 07:04 AM
SwapStang's Avatar
I had this happen to me on my last swap and it was driving me absolutely crazy! As soon as the weather changed and temp dropped I started experiencing this problem. If you reset the codes while the vehicle is running the pedal should come back,or at least mine did. I logged voltage on startup and it turned out to be a combination of a poor tac module ground, a weak battery, and poor placement of my positive voltage to feed my tac module. Once I got those 3 items squared away it's been great even with cold starts of 0 and below aren't an issue. There was nothing wrong with any of my components. I would log your voltage when you start it and see if it's getting a big drop or not. Good luck.
I will add in I adjusted my [Engine Diag>Airflow>Calc Airmass - P1514 / p0068 Error] in HPtuners since the car is turbocharged and I wasn't sure if this was causing an issue as well. You did mention you had a 408 so perhaps it is sending the airflow out of spec but I'm not sure if this would contribute or not just thought it was worth mentioning.
Old Feb 14, 2022 | 08:17 AM
qr409tz8's Avatar
Thanks SwapStang. This seems very plausible. I can certainly check the status of my ground and 12V on the TAC. My harness has been completely rebuilt so I can't guarantee those are as solid as they could be. The battery is fairly new, though I also cant guarantee that its not drooping at cold. The truck has been in the garage the past few weeks so no super cold starts for it meaning it hasn't had any issues since before I posted this.
