Radiator support
Old Feb 10, 2022 | 04:55 PM
RoyaltyGarage's Avatar
Default Radiator support
I’m swapping a ls1 out of a 99 corvette into a 73 camaro. I ordered a radiator for a 2000 camaro thinking it would work since it’s the same engine and I was wrong lol. The radiator ports for the upper and lower hoses are not the same size as what on the thermostat and on the water pump. I don’t really want to get a 99 corvette radiator because the corvette had a different set up with the separate coolant reservoir on the 99s. Can you guys help me out with some options? Will it create problems to put a thermostat housing on the water pump from a 2000 camaro if it will fit for the smaller hose size? Should I replace the whole water pump, and if I do that will it work with the other front accessories I have from the stock 99 corvette?
Old Feb 10, 2022 | 05:22 PM
theunderlord's Avatar
did some quick searching for you, check out the thread below. A few companies make radiators specific for LS swaps in many different older styles, BeCool, Griffin, Even Summit has some available too.
https://ls1tech.com/forums/conversio...l#post18540566.
Old Feb 10, 2022 | 05:29 PM
Jimbo1367's Avatar
You could get replacement radiator. Hose routing and witch FEAD will dictate which radiator you will need. Maybe a water pump too )
I have a Afco LS swap radiator. Haven’t run it long enough to see if it’s a good one or not. Summit Racing has dedicated LS swap radiators as well as name brand pcs too. You could just go with. generic LS swap radiators. I think B-Cool markets one LS Boneyard or something like that.
Theres a lot out there you don’t have to spend 1k.
Old Feb 10, 2022 | 06:37 PM
how much did you pay for that?
Old Feb 10, 2022 | 06:38 PM
yeah I’ve seen some of those but they are like $300 lol. That’s why I went with a oem from a camaro, it was $110
Old Feb 10, 2022 | 08:11 PM
HILROD's Avatar
I've used an LS Camaro radiator in a few swaps. They bolt right into most GM cars. The hoses were fine for me. Did you get a V6 rad?
Old Feb 11, 2022 | 02:51 AM
no it’s a v8 one but it was a LS Camaro Radiator and the engine was out of a 99 corvette so the hoses are different sizes
Old Feb 11, 2022 | 09:05 AM
Jimbo1367's Avatar
I tried this route. I couldn’t deal with the slanted radiator cap. Would of been a lot cheaper if it didn’t bother me Lol
Old Feb 11, 2022 | 09:50 AM
1964SS's Avatar
Just find the right hoses for your application. Nothing wrong with one side being smaller then the other. They actually make hoses with different end sizes.
